Chris NottAH Fabrications
Results 1 to 26 of 26
Like Tree3Likes
  • 1 Post By dkpeter
  • 1 Post By dkpeter
  • 1 Post By mfspen
Thread: TFSI 140 COD: vibrations in 2-cyl mode
    May 2014
    Madrid, Spain
    30
    Hi all,
    First message on this forum. Sorry about my English.
    I have an A3 (8V) 1.4 TFSI 140 bhp Cylinder-on-Demand (COD). I've noticed some rattle or vibration from the engine when running on 2-cylinder mode and stepping lightly on the throttle in the 1500-2000 rpm regime. If you increase pressure on the throttle the engine engages all 4 cylinders and the vibration disappears. Also, above 2000 rpm the vibration is not noticeable even in 2-cylinder mode.
    I'm pretty sure this is common to all units of this engine in the A3 or in the Golf VII (the engine is called there ACT - Active Cylinder Techonology, but it's the same as COD) . Some examples of people reporting this:
    - Rumble and Vibrations, Golf7 TSI 140 DSG Seite 3 : I'm just interested if I should contact my dealer about the up... This link talks about a software update that reduces the problem
    - (In Spanish. Refers to Golf VII with the same engine) Crítica personal 1.4 TSI ACT [Archivo] - Club VW Golf España
    - (In French) Que pensez vous que l'Audi A3 1.4 TFSI CoD - A3 - Audi - FORUM Marques
    How do you get by with these vibrations? Do you find them annoying? They are moderately annoying for me. Do you try to always run the engine above 2000 rpm to avoid them? Has anyone had a software update that solves or reduces this issue?
    Cheers,
    Luis
    Sep 2013
    East Sussex
    1,558
    I don't have any vibrations or rattle at all with my COD 1.4, but my car is manual. Rattles though, from the gearbox, seem to be quite common with many DSG equipped cars..
    Now a proud owner of a A3 1.4 tfsi Saloon S-Line, 6-speed, Daytona Grey, Technology Pack, Comfort Pack, Cruise, Advanced Key, Privacy Glass, Audi Parking System Plus, Interior Lighting, Folding Door Mirrors, Light & Rain Sensor. Hold Assist.
    May 2014
    Madrid, Spain
    30
    Thanks for your reply! Mine is manual too. Yes, I heard in DSG there are more vibrations. That may also be caused by the DSG always trying to engage a hight gear.
    Are you sure you don't have those vibrations? They are sligth, so you may not have noticed. If you don't mind, you could do a test: drive at about 1700 rpm and step on the throttle a little, so that you notice some acceleration, but not too much, so as to keep the 2-cyl indication on the display.
    Quote Originally Posted by cuke2u View Post
    May 2010
    24
    Isn't that roughly the same revs that the turbo 'kicks' in??.
    Just a thought!.
    Sep 2013
    East Sussex
    1,558
    Quote Originally Posted by LuisM View Post
    If they are slight I would put it down to an engine running as a two cylinder that is unlikely to be quite as smooth as a four cylinder, as engineering will show..
    May 2014
    Madrid, Spain
    30
    Well, the vibrations disappear as soon as the engine goes from 2- to 4-cylinder mode (by pressing increasing throttle pressure). So it clearly has something to do with the 2-cyl mode.
    May 2014
    Madrid, Spain
    30
    Sure! I also think it's something normal in a two-cylinder engine. I didn't mean it's something strange. I was just asking what do you people think about it, if you find it annoying, moderately annoying, or not at all; if someone has had a software update that alleviates the vibrations, etc
    Apr 2013
    23
    I have the 1.4CoD and stronic and do feel vibration when the 2cyl mode is activated and at times find it annoying but just as worried about if this could damaged the engine some how.
    Sep 2013
    East Sussex
    1,558
    How do you think any damage would occur, I am sure that the engines are tested to destruction....
    screenbubble's Avatar
    Mar 2014
    I read somewhere that early attempts at car engines with cylinder deactivation did vibrate them to destruction.
    However looking at the video below it seems with the Audi COD it's the small valves that stop, and the heavy cylinders keep moving as normal. So I'm not sure where any vibration could come from, looking at the animation.
    Maybe it should be called valve on demand, VOD!
    Audi A1 Sportback cylinder on demand - Animation - YouTube
    Apr 2013
    23
    I'm sure that audi has done their work and tested. I tested the 1.4CoD with manual gearbox and didn't notice the activation/deactivation of 2cyl mode. Only way to see was on the km/L usage.
    I need an automated gearbox so ordered with stronic. With the stronic I feel the activation/deactivation as vibration. The vibration are more pronounced just before the system decides to go from activation to deactivation.
    I can feel the vibration in the driver seat through my behind.
    Some has mentioned the DSG as the reason for the vibration but the are clearly related to the 2cyl mode as vibration disappears as soon as the car goes up hill a bit and 4cyl is enabled.
    Dec 2013
    64
    I do hear a slight change in engine noise when the 2 cylinder mode is engaged. You could call it a rattle but it's barely detectable and I wouldn't call it a vibration. This is with the s-tronic gearbox.
    Annoying? Not at all. The engine is the most refined 4 pot I've ever driven, whether in 2 or 4 cylinder mode.
    Sep 2013
    East Sussex
    1,558
    I agree with you that the engine is the most refined and the quietest I have ever owned too. Perhaps this is why to some sounds can be heard. To be honest I think the car should just be driven how it should and if anything that may happen be taken care of under the warranty when, and if, something actually drastically goes wrong...
    May 2014
    Madrid, Spain
    30
    Quote Originally Posted by dkpeter View Post
    I think with Stronic the vibration may be more pronounced than with manual gear, because the automatic gearbox tends to favor low rpm regimes, where vibrations are more noticeable. Specifically, I notice them under 2000 rpm while in 2-cylinder mode
    If you have drive select (I have manual without drive select), maybe using a different driving mode may help avoid the low rpm regime in 2-cylinder mode.
    And then there's the thread I mentioned in my first post, where they mention a software upgrade (for the Golf VII) that reduces the vibrations. I'll mention it to the dealer when I take the car for service
    Apr 2013
    23
    There is difference between the drive select modes and also a difference if I use CC or not to maintain constant speed.
    The software update that you mentioned I find very interessing.
    LuisM likes this.
    Sep 2013
    East Sussex
    1,558
    When were your cars built as it maybe that 2014 cars had a different map. The Golfs mentioned in that thread all seem to be 2013. Can anyone confirm when TPI 2036911/1 was issued for the Golf?
    May 2014
    Madrid, Spain
    30
    I have tested with CC on, and I think the vibrations are less pronounced, or even non-existent. Is that what you meant?
    What differences do you find between Drive Select modes? Is there a mode when vibrations are smaller or even disappear? (I don't have Drive Select, so I can't test)
    Apr 2013
    23
    The vibrations are most pronounced in efficiency mode or auto driving at around 70-75km/t with the CC enabled, the stronic will be in D6. When driving above the 90km/t the vibrations become non-existent.
    I don't think that the drive select makes the difference in the vibrations but more the speed and gear combination. The CC enabled properly makes it worse due to 2cyl mode is entered more frequenctly.
    LuisM likes this.
    Apr 2006
    571
    I have a Golf GT 1.4 ACT (manual), which has the same engine, purchased May this year.
    I have not noticed any vibration in 2 cylinder mode, at any revs. In fact, I have found it completely impossible to tell when the engine is in 2 cylinder mode, other than by observing the message on the display.
    Rexus likes this.
    Sep 2013
    East Sussex
    1,558
    Which is what other owners have noted as well as in road tests...
    Apr 2013
    23
    Booked a time at Audi dealership to have them investigate the vibrations. The service advisor informed me that I was not the only one with vibrations problem in 2.cyl mode and that they are in an ongoing investigation and dialog with Audi.
    Sep 2013
    East Sussex
    1,558
    I hope they find a fault with your car and fix it but what the service adviser has stated is news to me and this forum...
    May 2014
    Madrid, Spain
    30
    Well, that dkpeter is not the only one with vibrations is no news at all, as the present thread and this other show.
    The fact that Audi is investigating it can hardly be any news either. There's a an issue (a minor one, I admit) with the engine, so of course they should be investigating it.
    May 2014
    Madrid, Spain
    30
    I am very very interested in what they will you, dkpeter. Please post here if you have any other news in the future!
    I also went to my dealer, but all I got from them is that vibrations are normal in a 2-cyl engine; that that's a price you pay for lower petrol consumption. And so it may be; but if something can be done to reduce vibrations (even at the cost of a reasonable increase in consumption), I'm interested.
    Apr 2013
    23
    So I have returned from Audi after having a mechanic with me for a drive. He acknowledge (but of cause the vibration wasn't as pronounce as it can be) that there is vibrations but as Audi is investigating and working on a solution they cannot do anything on less is it something extra ordinary. I was told that Audi is working on a software upgrade that should fix the "comfort problem" as it was described. They where under the impression that the upgrade should be ready within a month or so.
    May 2014
    Madrid, Spain
    30
    Thank you for informing. This is good news!
    I also went to my dealer, and of course they said the vibrations were within normal range. Please let me (us) know if they contact you when the software upgrade is ready, so that I can go to my dealer again to have that update in my car.
  1. Replies: 27
    Last Post: 1st January 2014, 13:39
  2. A3 2.0 Tdi 140 BKD - vibration on idle
    By RyanB88 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd October 2013, 14:03
  3. A3 140 TDI VIBRATION AFTER REAMP ON LOW REVS
    By AntonTDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th February 2012, 15:40
  4. 2.0 TDI 140 bad vibration
    By biggles195 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th November 2011, 10:48
  5. A3 TDI 140, HELP Overboosting, Limp Mode!
    By Scholey3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th October 2011, 22:56
Tags for this Thread
