Yes, I have one. Approx 3mm x 5mm - only through the top coat, not damaged the undercoat. Anyone got any good pointers to touch-up techniques and/or which paint to use? Daytona Grey if that matters......
Thanks for the very quick responses
How long does the paint stay liquid for? Is it worth getting the 75ml bottle (to cover the next few years) or will it go hard after a few months and you'll need to buy new again? I only have 2 minor marks at the moment....
Not sure if we are talking at cross purposes here... I meant does the bottle of paint dry up over time. No point spending extra for the big bottle if the next time I come to use it, it has gone solid.... Having said that, it's only a tenner....It does dry out over time. Would say you have a good 5 minutes to use the special fluid to wipe off the excess.
I have around 10.000 miles and I have already like 30 stone chips while doing almost only motorways, I think the paint is complete sh*t but Audi refuses to do anything ...
A distance of 2 cars? That's nothing! Sounds like your are driving stupidly close to the person in front!
I'm starting to get a bit peeved with this. I now have 5 chips on the bonnet, using the paint/laq and getting a decent finish but what is up with the paint?
My old A3 had maybe 2-3 chips in 7 years! I'm driving at a further distance than I normally do after I had the first 2 chips and yet getting more, even one on the drivers door!
I believe the bonnet is aluminium so at least shouldn't rust but at this rate even though there is a distance of 6 cars between me and the person in front by his time next year I'll be wanting a respray.
Are others suffering?
Not me:someone tested the protective film from Audi ?
https://shops.audi.com/en_GB/web/zu...-plus-and-headlight-washer-system-8v0071316-9
Audi said:Not in combination with S line exterior package
Eww... that's bad!this is my bonnet, and there are more on the top of the bonnet and even on the doors ...
https://dl.dropboxusercontent.com/u/16802699/Audi A3/DSC05771-2.jpg
Thanks ds790/pulp84,
I've been using the applicator and one dollop is plenty, paint sits above level. So when using a cocktail stick, are you just applying one droplet or are you applying enough to make it level with original. Allowing to dry 6 hrs, applying same amount (as it may have sunk), repeat 3 times so should now have a raised bump of paint.
Apply some blending solution to remove half of bump away.
Do you use the solution to bring the raised paint down to correct level or just above, then use polish to try and reduce to correct level?
The colour looks spot on, so I'm hoping for a good result.
Appreciate the tips!
+1 for chipex. I was also sceptical but it worked wonders for me. I tried a cocktail stick with a traditional touch up kit but I kept bubbling the paint. Frustrating times. Chipex left a smooth clean coat 10/10
Ok great thanks MA3RC that helps. That's pretty much the process I followed but I'm finding the paint hasn't really filled the chip afterwards if that makes sense. Maybe I'm not putting a big enough blob over the chip or being too aggressive with the buffing afterwards...or both!
