EM TuningVolks Autos
Results 1 to 16 of 16
    Apr 2014
    32
    Thumbs up Audi Connect (aus) connecting via remote SIM Access Profile (rSAP)
    Hi guys,
    For those who have MMI® Navigation plus incl. MMI® touch but perhaps not Audi Connect, is it possible to still get Audi Connect?
    I know for a fact in Australia, the Audi Connect isn't available for us yet (due 2015). However, if we have MMI® Navigation plus incl. MMI® touch can we use Option 1 in this guide to get it working? http://www.audi.gr/etc/medialib/ngw/...k-guide-en.pdf
    Option1: connecting via remote SIM Access Profile (rSAP).
    Has anyone tried? Or can try?
    May 2013
    3,255
    I doubt it, your MMI unit likely won't have the modem installed to support this.
    Sport 2.0 TDI 150 Sportback in Scuba Blue, alcantara/leather, advanced key, audi sound system, comfort pack w/ ACC and park assist, deselect sports suspension, auto-dimming & folding door mirrors, electric lumbar support, heated seats, hold assist, non-smoking pack, side & lane assist, reversing camera, storage & luggage pack, tech pack with audi connect, tyre pressure warning, towbar, variable headlight range control, xenon light pack
    Apr 2014
    32
    Can it use the modem from my phone?
    May 2013
    3,255
    No, RSAP just allows the car to use your SIM card as though it were its own, not all the phone's features
    Apr 2014
    32
    The PDF suggests otherwise - it claims that Connect can be used only with the connection with a mobile phone (I know in the UK we are not 'allowed' to have this option, but the PDF from Audi seems to suggest that there's no real technical reason it couldn't be done??)
    Dec 2013
    I've wondered the same thing, and wondered if it's something that could be fiddled with using VCDS??
    Apr 2014
    32
    I think we've got all the hardware necessary. Screen 7" variant, MMI touch etc.. if the system can use our data connection from phone, then it should be a software modification to get it working.
    Problem is I am still waiting for my new car to be delivered so I can play with it and tweak it.
    Was hoping some owners now could try it?
    Mar 2014
    These threads on MotorTalk.de would suggest you can enable it with a software upgrade and a change using VCDS.
    Audi connect, 'Full connectivity' update (-> Daten-SIM & telefonieren per HFP)? : Audi A3 8V, 8VA & 8VS
    MMI touch Software Update : Audi A3 8V, 8VA & 8VS
    Here is the interesting bit translated to English.
    "Who has a version number from MHIG_EU_AU_P0337 and the "Full Connect" feature really needs must with VCDS (I have used v12.12.2) the adjustment in the unit "5F Informationselek. I." change.
    "Present" Set the adjustment value "(24) Vehicle configuration Sim_card_mode_switch" on.
    After a reboot, then you have under "Phone" -> "Settings" -> "Phone calls about" two choices "vehicle" or "mobile phone"."
    I would give it a go but I don't have a VCDS cable.
    Rob
    Using Tapatalk
    Apr 2014
    32
    Awesome news Mixalbum, good find.
    Now we just need someone to test it?
    Dec 2013
    I'm 99% certain that P0337 is the software version I have.
    edit: actually, I have MHIG_RW_AU_P0337
    I'd guess the RW is "Rest of World" as opposed to "Europe"
    Don't know that I'm willing to try putting the software on mine without someone confirming that it won't brick my MMI.....
    Apr 2014
    32
    Micky, can I ask when was your car built? Assuming it is an au variant? You just need a VCD to test it out now.
    Dec 2013
    it's about an October '13 build. It was one of the very first batch to arrive in Oz.
    mjcourtney's Avatar
    Jan 2013
    South England
    1,043
    How are you going to link your car to an account at my.Audi.com to use the Connect features? AFAIK only Audi can do this, although happy to be proved wrong!
    2013 8V Glacier White A3 Sportback 1.4 TFSI S-line Mnaual
    SE Suspension, Tech Pack, B&O, Comfort Pack, Electric folding mirrors, Park Assist, TPMS, Interior Light Pack
    Dec 2013
    290
    This above. Can't be done unless you have an account to connect. Has to be entered on the MMI, and must be enabled on the Audi servers.
    That said, if you create a myAudi account, you will be given an activation code for Audi Connec IF you have the MMI+ system, which we do. Bit useless as we can't enter it anywhere. But if the above firmware/VCDS works, then might work for us. That said, the FW version listed above is for the EU. I do not think it will work on our cars, as the FW will check the VIN/ECU for compatibility.
    Oct 2006
    54
    I have full connect in my 2014 S3 but there is no sign of rSAP (tried connecting with my HTC One with the android-rSAP.com app that I used on my previous S4 and A6 both with mobile phone prep high)
    As a double check, I tried an old Nokia which also has rSAP.
    Neither worked.
    When I queried it, I was told by Audi that they are not doing rSAP in any cars in the future, as it is a dead protocol that mobile phone makers are no longer supporting.
    Sep 2013
    East Sussex
    1,583
    The ablitly to rSAP was discontinued in 2013...
    Now a proud owner of a A3 1.4 tfsi Saloon S-Line, 6-speed, Daytona Grey, Technology Pack, Comfort Pack, Cruise, Advanced Key, Privacy Glass, Audi Parking System Plus, Interior Lighting, Folding Door Mirrors, Light & Rain Sensor. Hold Assist.
  1. Audi AMI USB connection
    By Schizophonic in forum New A3/S3 (8V Chassis)
    Last Post: 24th July 2013, 00:39
  2. audi-sport facebook connect
    By wibble111 in forum General Chat
    Last Post: 15th April 2011, 20:08
  3. Replies: 4
    Last Post: 6th February 2011, 19:40
  4. Audi A3 USB Connection - Is It Simply "Plug n Play"?
    By mrviews in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th January 2010, 22:24
  5. Audi Symphony & iPod Connection Options
    By 936ADL in forum In-Car Entertainment
    Last Post: 19th February 2008, 12:39
Tags for this Thread
