JMB RetrofitsEM Tuning
Page 1 of 2 12 LastLast
Results 1 to 40 of 77
Like Tree8Likes
Thread: Exhaust flaps (S3) - modify?
    Oct 2013
    Near Melton Mowbray
    1,097
    Ok people, let's get some collective brain power on this one.
    The exhaust flaps on our S3s must have a way of being tied open all the time surely - either electrically or manually with wire.
    I'm interested in this because my inner pipes are such a PITA to clean, the bit of black soot seems to just weld itself on and I'm having to resort to fine wire wool every wash now.
    I remember on the Aston V8 vantage it was a fuse that could be removed to leave them open all the time and I seem to remember there was something on the old RS3 that someone figured out.
    Anyone got any ideas how they work on our cars? Anyone got their standard exhaust on the bench after having a whole new system fitted?
    Are the flaps usually shut and then powered open or the other way around?
    Build Week 1: Panther Black S3 SB S-Tronic, black nappa, anthracite alloys, comfort pack with adaptive cruise and parking plus, active lane assist, adaptive xenons with variable range control and auto high beam, technology package HIGH with connect, B&O, tyre pressure warning, fold/dim/dip/heat mirrors, reversible boot liner, extended mono pur interior, privacy glass, hill hold assist, LED interior light pack, electric lumber support.
    steeve's Avatar
    Nov 2004
    UK
    753
    Certainly on the R32 Golf I had you disconnected the pipe to the mechanism on the silencer and plugged it with something most people used a bolt.
    Not sure if the S3 is the same, I'm sure some one on here will know.
    Steeve
    Pulp84's Avatar
    Aug 2013
    636
    Think you might need to use a proper metal cleaner rather than worrying about adjusting the exhaust system.
    My A1 185 has the same issue with carbon heavy deposits on the exhaust. Really annoyed me when I got it as my Mk5 GTI never did it. In the end I found this stuff the best Meguiars NXT Generation All Metal Polish - Clean Your Car.
    Over time fine wire wool will take the lustre away from the pipes. Using this stuff seems to build up a bit of a resistance for deposits sticking.
    S3 Sportback S-Tronic - Amalfi White, Comfort Pack, LED headlights, LED interior lights, High-beam assist, hill hold assist, privacy glass, mono-pur, folding mirrors, TPMS, Audi sound system and black Alacantra. Built week 17. Arrived 17/05/14. Wow......just wow
    Jul 2012
    Cheshire/N Staffs
    1,335
    Quote Originally Posted by steeve View Post
    That was using a vacuum actuator, same with the 8P S3. Just plug the vacuum pipe, and tie the valve flap rod open.
    Unfortunately the 8V is an electrically actuated (motor) system. You could try unplugging the motor and see if it throws up any Faults in VCDS.
    edit: Actually, don't do that. It may need VCDS to clear the fault code.
    From memory, the flaps open at idle, then shut until around 3000rpm, then open again. In Dynamic mode, they might be open all the time? If you do force them open 100% of the time, you could get unwanted boominess in the cabin.
    S3 8V 3DR DSG ACC ABS ADS AMI ASR ASS DAB DBW DIS DRL EBA EBD EDL EGR EPB EPS ESP GPS LED MFSW MMI PDC PSF RAC SDXC TFSI CO2 EEC OTR WTF OMG
    Oct 2013
    Near Melton Mowbray
    1,097
    Quote Originally Posted by Pulp84 View Post
    Yep, that's the metal polish I've been using and it almost works but not really well enough and I certainly haven't been expecting to have to *polish* them every single week - wash yes! Polish no.
    Pulp84's Avatar
    Aug 2013
    636
    Quote Originally Posted by Itguy View Post
    I'm very surprised by that as it's fantastic stuff! Bit worried now for when mine comes!
    Mar 2009
    Staffordshire
    1,243
    I was thinking exactly the same the other day. I have VCDS so if anything needs resetting, that's ok, and I don't mind being a guinea pig. I thought the flaps opened >2500rpm or something like that?
    Oct 2013
    Near Melton Mowbray
    1,097
    Yes I think that's right Scott. Want to have a play?
    Scott likes this.
    Sep 2013
    361
    Why don't you just set the exhaust to dynamic mode in the individual setting in the mmi to begin with?
    I can confirm that when unplugged it does show an exhaust flap fault in vcds.
    2013 Glacier White S3 Sportback S-Tronic
    Oct 2013
    Near Melton Mowbray
    1,097
    Quote Originally Posted by RobH_S3 View Post
    I have and always have had it in this setting. It still seems as though the flaps only open at 2.5k revs.
    Now I wonder if there is somewhere in VCDS that you can adjust the flap opening rpm?!
    Mar 2009
    Staffordshire
    1,243
    Did it make a sound difference with it unplugged?
    Jul 2012
    Cheshire/N Staffs
    1,335
    Logging Measuring Blocks 245, 246 and 247 will tell you at what RPM the flaps are open or shut.
    It's either fully closed, or fully (90%) open. No in between.
    Mar 2009
    Staffordshire
    1,243
    Quote Originally Posted by veeeight View Post
    Interesting. Thanks. I just unplugged what I assume are the flaps lol but not sure whether it's made a difference or not. I'll get VCDS and check what's going on
    Mar 2009
    Staffordshire
    1,243
    Ok we have fault codes
    2 Faults Found:
    21388 - Valve for Exhaust Flap 1 (N321)
    P3019 00 [047] - Open Circuit
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 3879 km
    Date: 2014.03.29
    Time: 20:28:48
    21399 - Valve for Exhaust Flap 2 (N322)
    P3023 00 [039] - Open Circuit
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 3879 km
    Date: 2014.03.29
    Time: 20:33:30
    No warning lights
    Sounds quite loud on idle in front of the garage. I will do some testing tomorrow and see what someone else thinks. I will also check measuring blocks but the battery on my laptop was 2% so it died before I was able to
    Mar 2009
    Staffordshire
    1,243
    Ok I'm not convinced I can tell a difference. If anything, it might be quieter at higher RPM's. I guess the flaps would need to be disconnected when they are open e.g. >2500rpm otherwise they would simply stay closed?
    Jul 2012
    Cheshire/N Staffs
    1,335
    I think they are open by default when the car is switched off.
    Mar 2009
    Staffordshire
    1,243
    I think you're right actually as I remember VCDS saying 'Open' when it was idling
    Anyway I'll give it a blast tomorrow and see what I think
    Need to tape up the connectors so they don't get dirty too
    Oct 2013
    Near Melton Mowbray
    1,097
    Good lad, waiting with bated breath!
    Would probably be easy to see if the flap was open when car off too by inserting something flexible up the pipe maybe?
    Mar 2009
    Staffordshire
    1,243
    I'll let you insert something flexible up the exhaust haha
    veeeight likes this.
    Oct 2013
    Near Melton Mowbray
    1,097
    Scott likes this.
    Jul 2012
    Cheshire/N Staffs
    1,335
    Are you offering up your exhaust Scott
    Form an orderly queue
    Scott likes this.
    Banned
    Oct 2009
    SW
    2,353
    I've found a quick raid in the kitchen to get some of this stuff works a treat.
    Cif | Stainless Steel
    Use with very fine wire wool if/when stubborn blackness needs removing, then just wipe clean... Mrs isn't that impressed though ;-)
    On the noise front.. it's a bit annoying that at 75-85mph in 6th the noise is at it's most annoying. Just the sort of motorway/autoroute cruising speed I like!
    Oct 2013
    Near Melton Mowbray
    1,097
    Well I've just been outside to see what I could test (don't have VCDS) and it seems like the valves are open when the car is off, and with the ignition on and with the car running at idle. I used a long flexible grabber that I've got in the garage and it certainly went in far enough to go past where the valve is located. Obviously couldn't test it at 3 or 4k rpm to see if the valve was open, shut etc. So maybe to only closes between off-idle and 2.5k??
    Scott likes this.
    Mar 2009
    Staffordshire
    1,243
    Lol.
    Ok all looks good to me. Doesn't sound too loud/boomy. I haven't tested on the motorway but I've tested on some quiet A roads. 30mph in 4th sounds louder, but not too loud, and certainly not noticeable with the windows closed/music up
    Still no warning lights, just the faults logged on VCDS.
    Easy enough to tape up the plugs/connectors with some electrical tape to protect them.
    I'd recommend it.
    Oct 2013
    Near Melton Mowbray
    1,097
    I wonder if there is anything that could be monitored in VCDS while driving to see what the normal flap behaviour is in the different individual modes (comfort, auto and dynamic)??
    Interesting that you can hear a difference. Is it a noticeable change over 'dynamic' when just pottering around then (windows shut)?
    Jul 2012
    Cheshire/N Staffs
    1,335
    Yes.
    Logging Measuring Blocks 245, 246 and 247 (plus RPM) in all the different Drive Modes will tell you at what RPM the flaps are open or shut.
  28. #27
    Oct 2013
    Near Melton Mowbray
    1,097
    Scott, another one for you mate as you have VCDS. I wonder if it is worth also recording throttle angle as the behaviour might be linked to that too??
  29. #28
    Oct 2013
    Near Melton Mowbray
    1,097
    Useful discussions over in Vw land ref the mk7 R exhausts.... R Forum • View topic - Exhaust Flapper Mod?
  30. #29
    Silky-S3's Avatar
    Is loving his new 8V S3!
    Jan 2009
    1,390
    I'd like to do this. Scott, so it's just case of getting under the car and unplugging the connectors? The valves stay open all the time then?
    I have VCDS so happy to do some logging if it helps the cause.
    S3 8V Sportback Stronic, Estoril Blue Crystal Effect, Black Interior, Adaptive Cruise with Stop & Go & Pre Sense, Super Sports Seats with Electric Lumber, LED Headlights, Interior Lighting Pack, Hill Hold Assist, Privacy Glass, Comfort Package, Technology Package with Audi Connect, Advance Key, Folding Door Mirrors, Extended Mono.Pur Interior, Front and Rear Parking Sensors, Audi Sound System.
    Build Thread Here!
  31. #30
    Oct 2013
    Near Melton Mowbray
    1,097
    That's what I understand. The flaps are electric obviously and are in a normally open state so I figure that as long as they are unplugged while open, they will stay open. A short burst of logging would be interesting just to know when the flaps usually are open / shut so we can tell where abouts we should hear a difference after unplugging / always open
  32. #31
    Mar 2009
    Staffordshire
    1,243
    It's very slightly noticeably louder with the windows closed but certainly nothing to write home about. It's a louder at slow speed/low rev driving and on acceleration from low rpm. It's a good improvement IMO. And yeh, just unplug the connectors on both sides and tape them up with some electrical tape to keep 'em clean
  33. #32
    Mar 2009
    Staffordshire
    1,243
    I'll do some logging, if no one else has, next week as I'm off to Spain tomorrow (last minute thing)
  34. #33
    Oct 2013
    Near Melton Mowbray
    1,097
    More talk on the R forum, but this log was only in "normal" mode not dynamic. R Forum • View topic - Exhaust valves - someone with VCDS please help!
    Scott - did you manage to unplug without jacking? I'm going to have a look at min tonight if it's not raining
  35. #34
    Oct 2013
    Near Melton Mowbray
    1,097
    Ok, have unplugged mine tonight without having to jack up the car etc, the plugs are easily accessible. Taped them up and cable tied the out of the way.
    Have a very quick run up and down the road and didn't really see any difference but it was such a short run, tomorrow morning will be the tell-tail run.
    As another thought, does the dash noise generator always work in all driving modes or does that change too? I like to drive my commute in efficiency mode but want it loud!
  36. #35
    Sep 2013
    16
    The dash noise generator will open only on dynamic or set manually via individual.
    Cant set efficiency and get sound
  37. #36
    Mar 2009
    Staffordshire
    1,243
    The only time you really notice (IMO) is when the engine is warm and slow speed stuff, pulling off, accelerating from low revs in high gears, it just gives a bit more sound. It's not noticeable at all really, but if you listen with the window down, it definitely makes a difference outside
  38. #37
    Aran383's Avatar
    Apr 2013
    Aberdeen/London
    68
    I just did this mod today, definitely a slight difference in noise - more boom, think the car should have come stock like this IMHO. Have the rest of you left it unplugged or have you returned it back to stock?
    Sold- Audi A1 1.4 TFSI Sport
    Sold- Brilliant Black Audi A3 8V S-Line 1.4 TFSI, SD card based Sat Nav, Privacy glass, S-Line suspension, Hill Hold assist, Audi sound system, Parking system.
    Now- Brilliant Black Audi S3 8V 3dr S-Tronic, SD card based Sat Nav, Privacy glass, audi sound, parking sensors-rear, Black styling pack, light and rain sensor pack, Tyre pressure monitor, Alcantara seats.
  39. #38
    Oct 2013
    Near Melton Mowbray
    1,097
    Mines been unplugged for a week now. Makes all 4 exhausts equally dirty now and actually much easier to clean as the soot concentration is now over 4 pipes rather than 2.
    I'm loving the sound and as I typically stick mine in Eco mode for my commute
  40. #39
    Mar 2009
    Staffordshire
    1,243
    Mine's still unplugged
    I want more sound now
  41. #40
    Aran383's Avatar
    Apr 2013
    Aberdeen/London
    68
    That's good! Always find it a pain having to clean the inner pipes if I don't wash it for more than a week
  1. Exhaust flap
    By Smiffi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd November 2013, 12:00
  2. How to: S3 exhaust flap mod
    By Staz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th January 2009, 12:21
  3. S3 Exhaust Flap
    By r18jsh in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th December 2008, 23:16
  4. Milltek and exhaust flap actuator
    By JustCharlie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th September 2008, 20:03
  5. 3.2 Exhaust Flap Disabled.
    By DavidR in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th February 2006, 16:55
