Is their a way to make the display on the screen bigger to remove the black border if you don't have technology pack?
Canot be done in VCDS and I believe someone here sourced a tech pack screen and installed it only to find that it was not comparable with the video driver in the standard MMI. All he saw once powered up were some odd coloured box's.
interesting, can you share your sources?
It was on here somewhere a while ago, I remember it too. The hardware in the standard MMI isn't powerful enough to power the tech pack screen, the actual unit is different as well.
Yes mine does, it is a little disappointing.Does the tech pack screen still have a small boarder inside the bezel for you guys? Mine does but im not sure if thats correct, its a bigger screen than a standard size but doesn't completely fill the lcd screen.
This what mine looks like
