Volks AutosJMB Retrofits
Page 1 of 2 12 LastLast
Results 1 to 40 of 46
Like Tree10Likes
Thread: Best audio quality - which input?
    Dec 2013
    288
    So, which would be the best input to use for sound quality? SD? Bluetooth? AMI?
    I know it depends on the quality of the source, but I'm not sure if the MMI uses the same DAC for all of input sources?
    Jan 2014
    Buckinghamshire
    80
    The best would be to use CD's.
    Audi A3 SportBack S-Line 1.4 COD, Phantom Black, Comfort Pack, Parking Plus, Transformer Door Mirrors, Technology Pack, Bang & Olufsen
    0B1001001's Avatar
    Sep 2013
    186
    Pretty sure it supports FLAC, so FLAC on SD card would be best (with embedded album art at 800x800). Not got my car yet but think that's what I'll be using.
    Arrived: MY14 S3 Sportback (Ordered 4th Jan, build week 12 (was 13), collected 23rd April), Manual, Monsoon Grey, Black Alcantara, LED Headlights, Interior Light Pack, Comfort Pack, Audi Sound System, ACC, Parking System Plus, Tech Pack, Electronic Folding & Heated Mirrors, Through Load
    Oct 2013
    411
    It will use the same DAC.
    Even if there was a difference, assuming the same source material (i.e. exactly the same file) it isn't going to make a blind bit of difference which input is used as any subtle nuances which might be better are going to be completely masked by any road noise (and I speak as an audiophile who has spent as much as a new A3 on audio equipment over the years).
    The best source file will be either direct from CD or FLAC files (I think the MMI plays FLAC files) as these are lossless formats. You aren't likely to be able to tell much difference between that and well compressed mp3s in a car though IMHO - due to the general environmental noise as mentioned above.
    warren_S5 and ConS3 like this.
    Sep 2013
    Denmark
    53
    AAC 320kbps from SD has an advantage of being immune to read errors - plus, you may hit the road with 1000 CD´s on a 128Gb card. That´s what I chose. I am an audiophile also, and I myself struggle to distinguish 320kbps from CD after two beers.
    edit: MMI can´t read files in FLAC or Apple lossless according to the manual, that states 320kbps as the upper limit, but I havent´t tested it.
    Ecosphere and ConS3 like this.
    Sep 2013
    Denmark
    53
    OT on: I cannot figure how to put my car´s details at the bottom of my posts like OB1001001! OT off
    0B1001001's Avatar
    Sep 2013
    186
    Quote Originally Posted by felsby View Post
    Settings at top, Edit Signature on left
    felsby likes this.
    Oct 2013
    411
    Apparently the tech. pack addon can according to posts on the forum......
    0B1001001's Avatar
    Sep 2013
    186
    If you want to save space vs. FLAC, I'd go for 320kbps VBR MP3.
    felsby likes this.
    RossR's Avatar
    Apr 2013
    490
    I've got tech pack with connect and can play FLAC at 48KHz, 16bit. I've not tried higher bit depth or sample rate, although I did successfully play a DVD with 96KHz, 24bit PCM audio. I doubt the DAC is anywhere near that quality, but it did play.
    oaf
    Mar 2014
    Nottingham
    Thumbs up
    AAC 320kbps from SD has an advantage of being immune to read errors ...
    First post(!)
    I tried to find on the web the maximum supported AAC bitrate and couldn't; however my car is happily playing ("True") [T]VBR Apple-encoded AAC files at the highest quality setting. Foobar2000 reports that the bitrate of these files often peaks (quite some way) over 320kbps but I haven't encountered any stutters yet, they all play fine. I've got a new S3 with B&O stereo but no tech pack.
    I used https://sites.google.com/site/qaacpage/ in conjunction with foobar2000 to transcode my FLAC files to AAC. This means I can use (the good) Apple encoder without installing the (not so good!) iTunes and have the flexibility of Foobar too. Killer samples aside I'd defy anyone to ABX the FLAC/AAC files (and that's before the car has started!)
    Hope this helps someone.
    felsby likes this.
    May 2013
    205
    Slightly off-topic but I tried a cd for first time in my week old car (been using Bluetooth...) and there is no track data showing on the MMI... What's wrong?
    snakehips's Avatar
    Aug 2013
    North Herts
    604
    Quote Originally Posted by 0B1001001 View Post
    Agreed. I have used both formats and really can't tell the difference in the car, but maybe this is because I'm running on Continentals...
    madrussa likes this.
    A3 SB S-Line TDi 184PS Quattro S-tronic. Shiraz Red, Tech Pack, Comfort Pack, B&O, Sunroof, LED lights, lots of other stuff.
    Aug 2013
    221
    Quote Originally Posted by PembsA3 View Post
    Yeah I have noticed this. It only shows cd track 1 only
    Sep 2013
    Denmark
    53
    mine shows all tracks. Standard MMI (w/o HDD, touch)
    A3 Sportback 180bhp S-tronic
    Amalfi white, Chestnut brown interior. Xenon, heated and retractable mirrors, sat nav, Audi Sound System, LED interior lights, detachable tow bar.
    Oct 2013
    Near Melton Mowbray
    1,097
    Quote Originally Posted by snakehips View Post
    Build Week 1: Panther Black S3 SB S-Tronic, black nappa, anthracite alloys, comfort pack with adaptive cruise and parking plus, active lane assist, adaptive xenons with variable range control and auto high beam, technology package HIGH with connect, B&O, tyre pressure warning, fold/dim/dip/heat mirrors, reversible boot liner, extended mono pur interior, privacy glass, hill hold assist, LED interior light pack, electric lumber support.
    Sep 2013
    Denmark
    53
    Probably :-)
    But seriously, 320kbps for in-car audio is really good enough.
    JohnnyM100's Avatar
    Jan 2013
    Hampshire/Surrey border
    461
    +1
    only tried recent CDs though. Perhaps older ones or burned CDs don't have CD-Text
    John.
    Enjoying my 8V
    0B1001001's Avatar
    Sep 2013
    186
    All this talk of actual, real CD's is just so 80's
    illingworth22 and felsby like this.
    Dec 2013
    A big, ugly and polluted south-Europe city
    87
    24 bit >48 KHz DACs are expensive stuff. I doubt that they fit a high-res high-sr DAC in a small family car. Maybe on bigger models. I think if you try to play hi-res material it is resampled before the DAC.
    I could be wrong obviously.
    May 2013
    205
    Brand new original recording cd - no track info - just "Track 1" "Track 2" etc... Surely that's not right with all this talk of people seeing videos and album covers via their MMI...
    Aug 2013
    221
    Yeah I'm confused. I've tried loads of CDs and none of them show the track names?
    illingworth22's Avatar
    Feb 2013
    Dublin, Ireland
    124
    Slightly off topic.... only just! I have all my music on my iPhone 5S and play via Bluetooth. How come some of the Album Art is displayed and other artwork is not? (Generic Artwork is displayed)
    My14 S3 3 Door (Audi Ireland Press Car) in Masano Red
    Options - Misano Red - MMI Navigation Plus (no DAB as it is not available here) - Audi Connect - Fine Nappa - Heated Seats - Heated Seats - Metallic Paint - 18" 5 Parallel Spoke Star Design Alloy Wheels - Bang & Olufsen Sound System
    Standard - Bluetooth
    - Drive Select - Music Interface - Presence Basic - Auto Headlight Range Adj - Exterior Chrome - Rear Park Assist - Xenon Lights with LED daytime running lights
    JohnnyM100's Avatar
    Jan 2013
    461
    Quote Originally Posted by RVP20 View Post
    What's your firmware version? See last few posts in this thread.
    What do we know about the MMI in the A3?
    Enjoying my 8V
    Jan 2014
    Witney, Oxford
    238
    Follow oufc1976 On Twitter
    Quote Originally Posted by RVP20:2119827
    Ditto that.
    Did some tests today. Compared Eminem's Without Me in lossless, MP3 and AAC (via iPod and SD)
    And whatever others may say, for me there is a massive difference between lossless and the compressed formats.
    As such, it's iPod all the way for me.
    Played a CD and was surprisingly underwhelmed although it wasn't the same track to be fair.
    Makes me think Audi scrimped on the CD transport
    8V A3 Saloon 2.0 TDi S-Line. Daytona Grey. SD Sat Nav. Privacy Glass.
    Oct 2013
    411
    Quote Originally Posted by oufc1976 View Post
    It does depend on what bitrate though.... 320k CBR or 192k VBR (mp3) are very difficult to tell apart from original - even on quite high end gear....
  28. #27
    Jan 2014
    Witney, Oxford
    238
    Both AAC and MP3 files were 320kbs
    The difference was most noticable in the low end frequencies.
    It's clear as day to my ears. But I accept its different for different people
  29. #28
    Oct 2013
    411
    I would challenge you to a double blind test... but my anorak days are behind me.....
  30. #29
    Aug 2013
    221
    Thinking of loading a 128gb SD card. What type of file should I put on it? ACC? Is this the best sound quality?
  31. #30
    0B1001001's Avatar
    Sep 2013
    186
    Quote Originally Posted by illingworth22 View Post
    Embedded image size greater than 800x800 pixels? I believe this is the limit.
  32. #31
    Sep 2013
    Denmark
    53
    Rvp20: yes, AAC 320 kbps was my choice.
  33. #32
    Jan 2014
    Witney, Oxford
    238
    Lossless every day.
    AAC/MP3s sound thin. And even the CD player, which in principle should be the best, sounds flat.
  34. #33
    May 2013
    205
    No matter how I organise the music files on the SD card, (e.g. by album...) the MMI always displays the files in track number order i.e. all the first tracks on all the albums first... Can't find any way of changing how they are sorted via MMI... Help anyone?..
  35. #34
    Jan 2014
    Witney, Oxford
    238
    Quote Originally Posted by PembsA3:2139955
    Similar question. How do you shuffle 'all' songs?
  36. #35
    May 2013
    3,225
    For the first one, I use the 'folder' view in the MMI media menu, just lets you browse by folder.
    For shuffle, it's just in the options for me. Load the whole SD card to the playlist and then put shuffle on.
    Sport 2.0 TDI 150 Sportback in Scuba Blue, alcantara/leather, advanced key, audi sound system, comfort pack w/ ACC and park assist, deselect sports suspension, auto-dimming & folding door mirrors, electric lumbar support, heated seats, hold assist, non-smoking pack, side & lane assist, reversing camera, storage & luggage pack, tech pack with audi connect, tyre pressure warning, towbar, variable headlight range control, xenon light pack
  37. #36
    May 2013
    205
    I don't have any 'folders' showing on the MMI - below 'SD Card' level I have all the tracks listed... Should I have put each album in a different folder on the computer when I ripped the CDs?..
  38. #37
    andy203's Avatar
    181 BHP
    Jan 2014
    Norfolk
    274
    I just copied and pasted the individual albums from PC to SD card, and they appear in the MMI in alphabetical order.
    Proud Owner - A3 Sportback 2 lt Quattro - S Line - Daytona Grey
  39. #38
    Sep 2013
    Denmark
    53
    Lossless every day.
    Seems like you have to blame the DAC, then.
  40. #39
    Sep 2013
    Denmark
    53
    Which program did you use to rip them?
    Yes, it would be a good idea to organise tracks in folders. The MMI cannot sort them for you.
  41. #40
    andy203's Avatar
    181 BHP
    Jan 2014
    Norfolk
    274
    I used Windows media to rip them.
  1. MMI 3G+ Best Sound Quality Files?
    By Ger7 in forum In-Car Entertainment
    Last Post: 19th October 2013, 07:18
  2. best audi headunit. Which do i pick?
    By chale989 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd February 2013, 19:31
  3. New HU or Aux Input Adaptor - which is best option
    By Nanz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th July 2012, 21:34
  4. A4 TDi 110 OR PD 115 Which is Best?
    By 18ME in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th January 2003, 00:44
