AH FabricationsBadger5
Results 1 to 8 of 8
Like Tree7Likes
  • 6 Post By RossR
  • 1 Post By RossR
Thread: 1.4 COD tuning box
    RossR's Avatar
    Apr 2013
    490
    1.4 COD tuning box
    Hi All,
    I've had a DTUK tuning box fitted to my 1.4 COD for about a week now, so thought I'd share my experience so far.
    The box in question is this one:
    DTUK FSR MultiChannel Petrol Tuning Box | chip tuning boxes from Diesel Tuning UK
    Fitting/Removal is pretty straight forward. You just unplug three sensors and connect each one again, but via the tuning box. The only difficulty is that to get to some of the sensors you need to remove part of the induction system. This can all be done with a pair of pliers, and takes about 10 minutes. If, like me, you live close enough to DTUK, fitting is even easier, as they can do it for you.
    There was a slight issue when my box first got fitted, but I put this down to it being the first one that had ever been fitted to an A3. The important thing form my point of view was how DTUK dealt with the problem. Suffice to say that a replacement part was couriered from Germany for the next day and all works perfectly now. Their customer service is simply excellent. I've got Andrew's (The MD) mobile number for technical support 24/7! Andrew is also a member on here (ABYSS), and offers a member discount.
    Claimed performance figures are 171ps and 298Nm. This is based on dyno'ing a Mk7 Golf with the same engine.
    Diesel Tuning box for Audi A3 1.4 Tsi 140ps Cod
    Comparing that to the official figures for the 1.8 TFSI, it's within 5% of maximum power, and has considerably more torque! The 1.8 is of course slightly heavier too.
    The box has a couple of adjustments on it. First of all there are two maps to choose from. Map 1 starts to fall off above 5000 rpm, whilst map 2 extends all the way. Secondly each map can be tweaked in aggressiveness from -3 to +3. When the box was first installed, it was set to a sensible configuration of Map 1, setting 0. Even that sensible configuration made a noticeable change though. As soon as I was happy that was working, we tried Map 2, setting +2, and it's stayed on that setting since.
    So what's it like to drive? Well, the COD engine was a great engine from the factory and the box has only enhanced it. Idling is just as smooth as stock, and it's just as easy to drive in a relaxed manner when you choose.
    Give it some throttle though and the difference is definitely noticeable. It really is hard to believe it's only a 1.4. At around 2000 rpm, it starts to really pull as the turbo kicks in. The torque builds quickly, but not so fast as to be harsh. From then on it just keeps pulling all the way to the red line, building to a slightly raspy sound. Drop it into 6th though and calm returns.
    Some time I'll probably try turning it all the way up to +3, but for now I'm very happy with it on +2. It really is like having a new engine.
    I can't say I've noticed an improvement in economy yet, but I have been driving it pretty hard and it is early days. I think the on board computer should still be accurate in this respect too as this particular tuning box leaves the ECU connected directly to the injectors.
    Any questions?
    Ross
    Sep 2013
    East Sussex
    1,563
    Thanks for the very good review. A tuning box is certainly something I will seriously consider in about a years time...
    Now a proud owner of a A3 1.4 tfsi Saloon S-Line, 6-speed, Daytona Grey, Technology Pack, Comfort Pack, Cruise, Advanced Key, Privacy Glass, Audi Parking System Plus, Interior Lighting, Folding Door Mirrors, Light & Rain Sensor. Hold Assist.
    STERLING VOID's Avatar
    Jul 2013
    South Africa
    102
    Please upload a dyno sheet.
    RossR's Avatar
    Apr 2013
    490
    This is from a Mk7 Golf.
    http://i26.photobucket.com/albums/c1...ps67f6eacd.jpg
    Mine hasn't been on a dyno (yet).
    STERLING VOID likes this.
    A3 Sportback 2.0 T FSi
    Jul 2011
    Congleton
    67
    I have the same engine in my Seat Leon FR and was wondering how this box works when you change modes (Sport / Normal / Custom).
    RossR's Avatar
    Apr 2013
    490
    In the Audi, the drive select still works. So if you put it into economy you get reduced throttle response unless you push it past the end stop. I'd assume the Leon is similar. To be honest I rarely have the throttle response on anything but dynamic.
    Jul 2011
    Congleton
    67
    Yes on the Seat you have ECO which dulls throttle and switches off AC, Normal, Sport (Faster throttle response, heavier steering and reduced traction control) and then a final Custom which lets you mix and match (I mainly use this with all the sport function on except for the heavier steering which gets a bit of a chore around town).
    I was concerned that in Sport mode and the box on it maybe a bit over aggressive, especially with the reduced TC.
    I recently moved from a 2.0TFSi A3 and although the new Leon is lighter the 1.4TFSi doesn't quite have the same get up and go so was weighing up a remap or this DTUK box.
    RossR's Avatar
    Apr 2013
    490
    Sounds very similar to the Audi system and I use the same settings on custom (everything on max apart from steering on medium).
    With the box and throttle response on maximum is still perfectly drivable. Sure, if you floor it in second in the wet you'll lose traction, but it's not difficult to control.
  1. Best TDi PD tuning box
    By KennyBradley in forum Tuning
    Last Post: 4th February 2005, 13:02
  2. 2.0 TDi 'tuning boxes'
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th December 2004, 23:26
  3. a3 Tuning Boxes
    By imported_pmcmaster in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2004, 13:22
  4. A6 Tdi 110BHP FWD Alpin Tuning Box
    By daver in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 1st September 2004, 13:03
  5. Can you get tuning boxes for SAME tractors??
    By smanning in forum Diesel forum
    Last Post: 17th July 2003, 09:55
