Badger5Volks Autos
Like Tree1Likes
  • 1 Post By madrussa
Thread: Which SD card for music?
    May 2013
    205
    Does any clever audiophile person out there know which SD card is best for music storage and use with a B&O? There are all sorts of different types of SD out there with different speeds and classes and wotnot and I haven't got a clue which to go for. Do I need a 'HC' card and is there any benefit getting a higher Class rating if it's just for music storage? E.g. There's no point spending 50 notes on a Sandisk SDHC Class10 when a standard Tesco SD Class 1 will do just as well!... I intend to store Lossless files for maximum quality so will probably have to go for a 64 gig card. Thanks very much in anticipation...
    Jan 2014
    Buckinghamshire
    80
    SDHC stands for Secure Digital High Capacity and enables SD cards to support over 4GB up to 32GB. You'll actually need a SDXC for a 64GB card... if a SDHC card specifies 64GB then it's not conforming to standards and may not work.
    You'll be mostly interested in the class of the SD card. There are 6 classes to choose from 2, 4, 6, 10, U1 and U3. Each has a different speed for different purposes. Considering that you can record video on a class 2 card and video bitrates are higher than audio you are normally good for using that for most audio. Generally the lower class are usually made by less considered companies trying to make a buck and would not last quite as well. Also the lower classes will take much longer to copy your audio to. Most class 10s are pretty reasonable price wise these days and give you good copy speeds. You may find it difficult to locate a lower class 64GB card.
    Hopefully that gives you enough information to make your decision.
    h5djr likes this.
    Audi A3 SportBack S-Line 1.4 COD, Phantom Black, Comfort Pack, Parking Plus, Transformer Door Mirrors, Technology Pack, Bang & Olufsen
    Jan 2014
    Buckinghamshire
    80
    I found a 64GB card for £24. Integral are usually good.
    Integral 64GB Ultima Pro SDXC 40 MB/s - Class 10: Amazon.co.uk: Computers & Accessories
    May 2013
    205
    That's great guys - thanks very much for the input. I wish I was more cleverer! ;-)
  1. Replies: 33
    Last Post: 24th April 2014, 13:28
  2. How to transfer Music from iTunes to SD card for the car?
    By Tom75 in forum New A3/S3 (8V Chassis)
    Last Post: 12th September 2013, 12:32
  3. Which SD card for RNS-e
    By aa_autos in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th August 2013, 03:03
  4. are the memory card slots on my stereo for music or sat nav maps?
    By Lee Applin in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th June 2012, 10:46
  5. WHICH BRAKE PADS FOR S3??
    By dans3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th July 2003, 07:59
