Chris NottSky Insurance
Results 1 to 17 of 17
    Dec 2013
    173
    10GB HDD in Technology Pack: Why?
    Can anyone explain the purpose of the 10GB hard drive that you get with the Technology Package? Audi doesn't seem to explain what it is used for. Surely the only justification for a spinning drive in a moving car is because it's cheap to store a lot of data - but at a tiny 10GB, that can't be why.
    When two solid-state SDXC cards can store up to 2TB, it just doesn't make sense to me!
    Also, is it worth the extra £300 for Audi Connect? I have a spare SIM/contract with data for the next 12 months, and after that I can pay EE £5, so that element is not an issue for me. I'm just wondering if the money could be better spent on a B&O sound system, for example.
    May 2013
    3,184
    The HDD stores the sat nav data basically. I agree it's rather small if they intend you to rely on the jukebox function, I don't use that myself.
    I have connect and love it - some really great features in there.
    Sport 2.0 TDI 150 Sportback in Scuba Blue, alcantara/leather, advanced key, audi sound system, comfort pack w/ ACC and park assist, deselect sports suspension, auto-dimming & folding door mirrors, electric lumbar support, heated seats, hold assist, non-smoking pack, side & lane assist, reversing camera, storage & luggage pack, tech pack with audi connect, tyre pressure warning, towbar, variable headlight range control, xenon light pack
    Dec 2013
    173
    Quote Originally Posted by cemerson View Post
    Can you ever hear the HDD scratching when the engine is off? Wish they could have used a flash drive instead.
    May 2013
    3,184
    No, have never heard it. I'd be very worried if it made a scratching noise! I'm not sure why they didn't use an SSD either... but can't say it's been a problem.
    Oct 2013
    According to the brochure it's "flash memory for music". I assumed this is solid state.
    May 2013
    3,184
    Oh, perhaps it is then - though the first thing it says is HDD based sat nav, which doesn't tally with that. They could use 2 separate drives I suppose...
    Dan_G's Avatar
    Dec 2013
    SW London
    149
    I have HDD / jukebox in my A4.
    I haven't been able to write anything to it in 3 years due to copyright security etc.
    Schizophonic's Avatar
    Jul 2013
    Northampton
    316
    Just pulling form a side question, if I manage to source the higher res screen of the MMI, will I be able to do a straight swap and utilise the higher res screen with the rest of the standard screen?
    mjcourtney's Avatar
    Jan 2013
    South England
    1,028
    Quote Originally Posted by Schizophonic View Post
    Sadly not, someone tried this about 6 months ago and the high res screen isn't compatible with the standard MMI. I assume because the standard MMI outputs a lower resolution video feed.
    2013 8V Glacier White A3 Sportback 1.4 TFSI S-line Mnaual
    SE Suspension, Tech Pack, B&O, Comfort Pack, Electric folding mirrors, Park Assist, TPMS, Interior Light Pack
    Jul 2013
    Northampton
    316
    Quote Originally Posted by mjcourtney View Post
    Really? Do you know what the thread is? If I want the high res screen then I've got to acquire the whole kit and get it fitted in? Assuming its all the same minus a couple tweaks here and there?
    May 2013
    3,184
    I would assume that this is correct - the base unit for the tech pack must be different as it has the HDD for a start, so no reason why they wouldn't tie the screen into it as well.
    mjcourtney's Avatar
    Jan 2013
    South England
    1,028
    Correct. I think it was a chap from Germany that tried it last year. He did post his findings but I can't for the life of me find the posts now (I think they were buried in the middle of another topic on MMI). From memory, he had the standard MMI system and bought the larger screen assembly, however when he powered it up the screen was split into 4 sections and wouldn't display anything meaningful. I think he tinkered with VCDS to see if anything could be adjusted but came to the conclusion that the display driver in the MMI system is different if you have the large screen. Therefore the larger screen would require the full MMI Tech Pack unit to drive it.
    I think you'd be looking at thousands to retrofit this by the time you'd changed the central unit, display, and control unit (as the tech pack has touch controls).
    Apr 2013
    East Sussex
    157
    It's not just the screen - its the signal driving it. You can't put a high res screen on a low res source and expect it to be high res. The screen can only display what it's fed with. Try putting s-video into a modern HD display - same thing.
    And I would very much doubt there is a 'HDD' anywhere. It's just terminology - it will be solid state memory.
    A3 2.0 TDI Sportback Sport : Scuba Blue : Xenon Light Pack : Technology Pack : Audi Sound System : DAB : Hill Hold Assist : Comfort Pack....
    and Sport Suspension
    May 2013
    3,184
    Yeh, I had thought that could be the case, seems strange that they differentiate between the 2 in the same description though!
    I've never heard an HDD spinning so think it probably is all SSD really.
    May 2013
    3,184
    But on that front... I wonder how easy it would be to upgrade the SSD - whether it's on-board memory or a separate SSD component, potential to add more space there.
    Apr 2013
    East Sussex
    157
    I would guess that its some sort of memory card or module, maybe like PC RAM or something along those lines. Just a guess though.
    May 2013
    3,184
    I was thinking that it would just be a standard 2.5" form-factor SSD, they are readily available, small and conform to a standard interface so easily swappable if Audi run into supply problems or something.
  1. Technology Pack 2010 TT
    By mike c in forum TT/TT-S/TT-RS Forum
    Last Post: 16th November 2013, 08:53
  2. Technology Pack Video Formats
    By xrkt77 in forum New A3/S3 (8V Chassis)
    Last Post: 31st July 2013, 19:45
  3. Technology Pack
    By Lion Man in forum New A3/S3 (8V Chassis)
    Last Post: 21st March 2013, 21:02
  4. Sportback Free Sat Nav Offer Ends - Technology Pack Price Rises
    By Peterdona in forum New A3/S3 (8V Chassis)
    Last Post: 1st March 2013, 13:12
  5. Audi Technology Pack when Spec'd
    By L33TAY in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th March 2010, 22:10
