EM TuningVolks Autos
Results 1 to 8 of 8
    Jun 2013
    Trinidad W.I.
    133
    pressure release sound from engine bay when engine is stopped
    hi all,
    i have the fwd 1.8tfsi, 4700kms
    does anyone hear a sort of hissing (pressure release) sound that pulses (hisss stop hiss stop etc.) when they switch off their engine when returning home from a trip with the car?? the sound only lasts a couple of seconds .
    I am not sure if it is venting pressure from the turbo that might still be spinning slowly ( i do give a minute or 2 spool down time before i switch off)
    i also noticed a very very mild oil stain on the plastic shield right below the oil fill cap. The cap seems to be spring loaded as well. I hope i do not have some kinda back pressure problem.
    car doesnt seem to be burning any considerable amt of oil either.
    Car drives fine tho.
    any ideas?
    Jun 2013
    London
    184
    I have the same engine. Not noticed a hiss but will keep my ears open.
    I also have a small oil stain near to the filler cap. I check the oil level regularly and it doesn't seem to be burning much if any. I put the stain down to the dealer topping up the oil during the PDI.
    A3 8V 1.8T 6 speed 3 door S line - Daytona Grey. Interior lighting pack, privacy glass, comfort pack, electric folding heated dimming door mirrors, tyre pressure monitor, electric lumbar support, cruise control, acoustic parking system rear, B&O sound system.
    Jun 2013
    Trinidad W.I.
    133
    Yea I think the oil was a bit overfilled and maybe some vapor came out when I did some red lining ? Who knows ? I read somewhere that the pulsing hissing could be a/c so I will have to drive without a/c and see. The hiss does seem to come from lower left area of engine bay
    Thanks for your response Tim
    Jun 2013
    Trinidad W.I.
    133
    Lower left as in passenger side
    Dan_G's Avatar
    Dec 2013
    SW London
    149
    Air con compressor.
    Jun 2013
    Trinidad W.I.
    133
    Could very well be a/c, btw how much kms have you done so far Tim?
    Jun 2013
    London
    184
    3100ish, not had much chance to use the car since I got it at the beginning of September unfortunately.
    Jun 2013
    Trinidad W.I.
    133
    Ok well it did lose some oil since last I checked. The level is a bit lower than half at the current mileage of 4700 kms . I'm monitoring it carefully and bought some top up oil incase it gets too low b4 5000 kms ( service)
  1. Squeal from engine bay when ignition turned on
    By Stringster in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th July 2011, 17:54
  2. Hissing from engine bay when car switched off..
    By Dans-first-Audi in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th July 2008, 15:11
  3. Noise from engine bay of TDI...
    By Bigman in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th August 2007, 21:22
  4. Help, tick tick coming from the engine bay?
    By imported_ashs3 in forum Tuning
    Last Post: 5th June 2005, 13:23
  5. Burning smell from engine bay a3 1.8T
    By lowrider786 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th February 2005, 20:05
