EM TuningAH Fabrications
Results 1 to 15 of 15
    Dec 2013
    7
    Audi connect question
    Hi
    I write from Italy and I congratulate you for the wonderful forum
    I'm going to order an A3 sportback 1.8 TFSI Quattro Stronic and I wanted to put the optional Audi connect, but the dealership did not seem very safe and the responses they give me.
    I ask those who have the 'it ..... but you can also call putting a sim that over the data service also works as a phone?
    Today I own an A4 TFSI Quattro Av Stronic and putting in the MMI navigation plus a second sim, it becomes a car phone in all respects without bluetooht and using the external antennza, improving the signal and resetting the electromagnetic waves inside the cockpit.
    As an alternative to the A3 c 'is the audi phone box ... that is connected to an external antenna via planar should simulate what I just described. (Less Sar and best signal) for 700 € ... but honestly I do not understand much utility except that the reduction Sar.
    thanks
    26,747
    Sera.
    Where in Italia?
    Dec 2013
    7
    Sera.
    Where in Italia?
    Ciao
    Turin
    May 2013
    2,805
    At least in my version, you can use the inserted sim card for data and phone if you want, or data only (with phone being over bluetooth)
    Sport 2.0 TDI 150 Sportback in Scuba Blue, alcantara/leather, advanced key, audi sound system, comfort pack w/ ACC and park assist, deselect sports suspension, auto-dimming & folding door mirrors, electric lumbar support, heated seats, hold assist, non-smoking pack, side & lane assist, reversing camera, storage & luggage pack, tech pack with audi connect, tyre pressure warning, towbar, variable headlight range control, xenon light pack
    26,747
    Quote Originally Posted by dtax View Post
    Ciao
    Turin
    Torino, ah ok, inglese bene, benvenuto.
    Dec 2013
    7
    Quote Originally Posted by cemerson View Post
    Hi and thanks for the reply.
    But if I have the audi connect with the sim for the phone, bluetooth audi phone box and I do not need more or not?
    Dec 2013
    7
    Sorry for my bad English. :-)
    thanks
    May 2013
    2,805
    You cannot order the Audi phone box with Connect, at least not in the UK. Pretty sure it would be the same everywhere though.
    Dec 2013
    7
    I'd be happy if I can connect with audi call from sim
    If so I do not need bluetooth connection for phone calls.
    But with Audi connect, the sim has an external antenna for phone calls?
    May 2013
    2,805
    Yes, there's an external antenna. It can use the SIM in the glove box, or your phone through the bluetooth remote sim access protocol (RSAP), which essentially does the same thing but with the sim in your phone instead.
    Oct 2013
    Near Melton Mowbray
    1,089
    Isn't RSAP deleted from the spec since the brought in 4g compatibility?
    Build Week 1: Panther Black S3 SB S-Tronic, black nappa, anthracite alloys, comfort pack with adaptive cruise and parking plus, active lane assist, adaptive xenons with variable range control and auto high beam, technology package HIGH with connect, B&O, tyre pressure warning, fold/dim/dip/heat mirrors, reversible boot liner, extended mono pur interior, privacy glass, hill hold assist, LED interior light pack, electric lumber support.
    Sep 2010
    Horsham
    222
    Quote Originally Posted by Itguy View Post
    i'm sure I read that too, apparently LTE was introduced in Italy in late 2012 (according to google at least) so one would assume that The Italian version of Audi Connect is LTE compatible as a matter of course, might be worth checking though.
    Dec 2013
    7
    Hi Cemerson
    So it works as a car phone in my A4 TFSI, just have a second Sim card that supports both 3g/4g and voice telephony.
    At this point, you no longer need the 'AUDI PHONE BOX P to have less radiation Sar.
    Right?
    May 2013
    2,805
    The phone box's main purpose is to boost the signal by using the car's external aerial. If you use the SIM card in the car (or RSAP over bluetooth - although not available any more it seems) it'll do that anyway.
    Dec 2013
    7
    Cemerson I thank you and I go to Audi to make me confirm what you said, since according to the Italian audi audi connect you can not call. I'm confused.
  1. Buying from an audi dealer... Questions
    By jwhat in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd April 2007, 19:21
  2. audi 4000 question
    By imported_DUB in forum Classic Audi Forum
    Last Post: 9th November 2004, 20:27
  3. Audi A4 question!!!!
    By imported_BigSte in forum General Chat
    Last Post: 17th September 2004, 20:48
  4. New to audi's questions
    By imported_WRX2A4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th September 2004, 05:02
  5. Audi stereo question - please help!!!! Concert to Symphony
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th May 2004, 14:45
