Monster MotorsportChris Nott
Results 1 to 16 of 16
Like Tree14Likes
  • 1 Post By dieseldoug
  • 1 Post By Itguy
  • 1 Post By arad85
  • 1 Post By Fragup
  • 1 Post By Daveotto
  • 1 Post By chrisinns17
  • 1 Post By Fragup
  • 4 Post By Fragup
  • 2 Post By dieseldoug
Thread: Audi a3 8v tracking settings
    Sep 2013
    48
    Will a Independant tyre specialist have wheel alignment settings for the new a3 yet as it's new ? Anyone know of any well known ones ?
    dieseldoug's Avatar
    Oct 2012
    Aberdeenshire
    240
    How long will you go on about this steering, alignment, steering wheel position before you decide their is nothing wrong with your car.
    If you still have issues contact Audi customer care and get this sorted out. For me I clearly think you haven't got a clue about cars and the way they operate.
    cajpaj likes this.
    A3, 2.0 TDI, S-Line, 6 speed manual, Scuba Blue, S-Line suspension, heated/folding mirrors, privacy glass, fine nappa leather, heated seats, light/rain sensor pack, flat tyre indicator, Purchased and supplied by Aberdeen Audi
    Sep 2013
    48
    Oh but I have .. I've worked in the motor trade for 16 years for your information .. And I work in a multifranchised garage .. This is my 3 rd Audi and I have never experienced this before .. The car is shared and we both notice the problem .. I have took the car to Audi And they can see a problem but say settings are fine ! I won't pay 28k for a car and not do anything About it .. I'm using this forum for help and advise and quite frankly your comments are rude and patronising .. Please don't reply if u haven't got nothing decent to say
    Oct 2013
    Near Melton Mowbray
    1,097
    Quote Originally Posted by chrisinns17 View Post
    hear hear. Now, back on topic,
    I would have thought the big places such as Qwikfit would have the settings but they would tend to use a hunter machine anyway. I wonder if your best bet is to ring a few local 4 wheel alignment places around you. Near us we have one in Leicester and in Nottingham who are very good.
    Failing that, the settings will no doubt be on the Audi computer system that has all of the repair instructions and procedures. I've not seen a copy of this for the 8v yet but a bit of searching might turn something up?
    for what it's worth I can totally understand your OCD (no offence intended) with this issue. I'm a right stickler for everything with my car being just right and I too have years of experience of fixing, driving and building cars so can just tell when it isn't how it I should be. You get a feeling don't you.
    i have a similar issue with our mk5 golf gti. I think it is taking longer than it should to warm up. It does get up to 90c but it takes 20 mins! Can't be right, so fitting a new thermostat later today. Most people would have just accepted it as the norm but It just doesn't feel right.
    chrisinns17 likes this.
    Build Week 1: Panther Black S3 SB S-Tronic, black nappa, anthracite alloys, comfort pack with adaptive cruise and parking plus, active lane assist, adaptive xenons with variable range control and auto high beam, technology package HIGH with connect, B&O, tyre pressure warning, fold/dim/dip/heat mirrors, reversible boot liner, extended mono pur interior, privacy glass, hill hold assist, LED interior light pack, electric lumber support.
    Oct 2013
    398
    I'm not an expert, but I would take it to a specialist 4 wheel alignment place that can also check caster angle. A lot of places will only check toe in/out and some will also check camber, but steering and wheel alignment is a 3 dimensional thing and a slight discrepancy in any one parameter can cause issues.
    Someone knowledgeable with wheel alignment can also tune out issues which are present dynamically, but not when measured statically (wheel alignment, by its nature is static, but at 70mph on a motorway, the steering is definitely dynamic!).
    Jun 2013
    East Sussex
    462
    Quote Originally Posted by arad85 View Post
    I agree, Again, I am not an expert (only just a novice) but makes sense that because the speed effects the steering, it sounds more like the increased force of the wheels spinning faster / traction on the road, if not balanced / perfectly set up, is the more likely cause.
    surly if it was the steering wheel / rack, it would happen at low speeds to ?
    I know you have new tyres, probably far to earlier to tell, but have you checked to see if the ware on the tyres is even / the same on each as that might indicate a difference. I must have hit a pot hole in my last car and although I didn't notice it knock a wheel out a bit and wore through the inside edge of the tyre quite quickly where it was out.
    good luck, i really hope you get your solution,
    If not, don't let it ruin your enjoyment of the car, its a small thing and as is still a cracking car.
    A3 sport back, Misano Red, S Line, 1.4 C.O.D. Manual, Panoramic Sunroof, Audi sound system, Folding mirrors, Interior lights pack, Non smoking, Delete Badges, Sports suspension, Hill hold & 2 year servicing & 4 year warrantee.
    Daveotto's Avatar
    Mar 2013
    Hertfordshire, UK
    906
    As I have said on previous post on one of the other threads on this topic.......Unfortunatly it would appear to be an issue with your car only and not a wider issue.
    In your words your dealer said there is a problem but settings are fine but car is still under warranty so suggest you take up again with the dealer or direct with audi UK.
    not sure why you want details on s specialist wheel alignment centre when you have been in the motor trade for 16 years plus a location would be handy as no point recommending somewhere in Scotland if you are in the South West, that said I would still be getting my dealer under the warranty to investigate further.
    dieseldoug likes this.
    A3 Sportback 2.0TDI S-line, - Daytona Grey, comfort pack, interior light pack , aluminium roof rails, Audi speakers, folding door mirrors, hill hold, sport suspension, no smoking pack.
    dieseldoug's Avatar
    Oct 2012
    Aberdeenshire
    240
    If you had 16 years experience in the motor trade I would not be asking these questions regarding you steering issue.
    If you follow the Ackerman principle of steering you may find your answer.
    Failing that I would be leaving the car with the dealer until the corrections have been made and pointed out as before in previous post to contact Audi customer care.
    Battlekrapz likes this.
    Sep 2013
    48
    Been to a specialist today and NSF was completely out .. Been adjusted and car is now perfect .. Took bill to Audi and are reimbursing me on Monday for tracking I had to pay for and fuel ... Did Audi ever check my steering .. Prob not ! Thanks guys for your comments who were actually helpful ! And as said before being rude and patronising for the others shouldn't be allowed on this forum . Enough said .
    Belfin likes this.
    Oct 2013
    Near Melton Mowbray
    1,097
    Excellent news, glad you got it all sorted. Makes you wonder how a brand new car with quAlity control processes etc can be delivered like that!
    Jun 2013
    East Sussex
    462
    Glad you sorted it.
    Audi should have picked up on that, at least they are paying !
    dieseldoug's Avatar
    Oct 2012
    Aberdeenshire
    240
    Glad you got it sorted, but still strange ONLY the NSF out in tracking!!! Tracking is both wheels.
    Was your car out in turns only the NSF was out?
    If you need to make a statement please make sure all the information is correct as I do.
    Belfin's Avatar
    Apr 2013
    Cornwall
    107
    Quote Originally Posted by dieseldoug View Post
    All your information is correct eh Doug - just not necessarily in the right forum, ha, ha, ha!
    Questions V's book
    "Let he who is without sin cast the first stone", etc!
    Very proud owner of Audi A3 Sportback S Line 2.0TDI in Daytona Grey.
    Comfort Pack, Light & Rain Sensor Pack, Audi Sound System, Heated Front Seats, Panoramic Glass Sunroof, Sat Nav (SD Card Based)
    Ordered April 14th, Delivered June 24th.
    Jun 2013
    East Sussex
    462
    may be correct, but not exactly overly friendly, no ones perfect,
    the guy is just worried about his car, so live and let live.
    Louay, Belfin, Battlekrapz and 1 others like this.
    Feb 2013
    117
    Glad it got sorted in the end
    dieseldoug's Avatar
    Oct 2012
    Aberdeenshire
    240
    Chrisinns17
    As mentioned above your tracking is repaired which I am glad to hear, but can you check your car is correct by making sure your car is in the straight ahead position and steering wheel centred, turn the car to full lock in one direction and count the turns and make sure it does the same amount in the opposite direction. If the difference is great you may have to get the steering rack centred to prevent "pulling" that will be the final test in your steering issue.As mentioned again I am glad your issue has been resolved.
    Louay and Fragup like this.
  1. audi a3 8L track car
    By jsmotorsport in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th February 2012, 18:07
  2. Audi s3 full suspension set up 8l
    By Dani_B19 in forum For Sale/Wanted - Audi Parts
    Last Post: 29th August 2011, 20:09
  3. Audi S3 K04 Turbo Set Up
    By motfree in forum For Sale/Wanted - Audi Parts
    Last Post: 23rd August 2011, 11:28
  4. how much are these worth: AUDI S3 FULL BRAKE SET UP.
    By Lewbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th September 2010, 18:12
  5. audi 80 tdi torque settings
    By manghan in forum Classic Audi Forum
    Last Post: 21st September 2010, 20:35
