Audi Connect - Updating for last 2 days ?
rdgc
NULL
Has anyone else had issues with Audi Connect currently not working ?
Sat Nav is stuck on TMC only, rather then "online" and going to Audi Connect just says that it is currently not available
the SIM card is definitely good i've checked that, and it says in the network status that it has good service
wifi hotspot also works great...
Just wandered if this is my car or if anyone else has had similar issues ?
cheers
Yeh, I have now you mention it. Perhaps their web service is down.
I do find it loses signal very easily, even when it's showing some signal in the status it'll claim not to have any sometimes, but since you mention it I've not been able to use any connect services over the past few days.
Thanks for the reply, I called my local dealer about it and they said I can pop it in and they can take a look, will let you know what they say
Cheers.
If it is their service that has gone down and they aren't monitoring it to know, I'd be pretty shocked!
Well no fix so far unfortunately... they are looking to do a software update and/or replace the control unit but that takes a few days to come in...
The issue changed today to just showing "System is unavailable" in both the Audi Connect menu and if you did anything involving Google via the Nav system, so if you have the same thing then maybe worth speaking to local dealer too
cheers
Mine works again today, I tried it this morning.
I find it annoying you canet use the google earth view and traffic view on top of each other - you can only overlay the traffic on the standard map view.
This doesn't sound good. Does connect go down often?
No, never happened before (other than having no signal)
Sounds like it is a one off issue with my car, so glad it is working for you OK... I haven't had a chance to play around with it properly yet so will have a look at the google earth bits once fixed again!
19
2K
31
4K
726
579
