Badger5JMB Retrofits
Page 2 of 2 FirstFirst 12
Results 41 to 51 of 51
Like Tree7Likes
Thread: Connecting an external HDD
  1. #41
    NotquiteWelsh's Avatar
    Sep 2013
    135
    I have tried one formatted NTFS which it could not reconise. The blurb indicates if it was FAT formatted it would be OK, at present I'm trying to find my 1GB FAT formatted portable HDD. When I do I will try it.
    Week 40: Brilliant Red S3 SB, manual, luna silver alcantara, anthracite alloys, comfort pack, non smoking package, tyre pressure warn, folding mirrors, cruise control, rear parking sensors, SD-satnav.
    Delivered on-time.
  3. #42
    May 2013
    3,255
    Oh, I might not be much use then as I'm pretty sure mine would be NTFS formatted. That's a shame, the filesystem has been around 20 years now, you would have thought it would be supported.
    Sport 2.0 TDI 150 Sportback in Scuba Blue, alcantara/leather, advanced key, audi sound system, comfort pack w/ ACC and park assist, deselect sports suspension, auto-dimming & folding door mirrors, electric lumbar support, heated seats, hold assist, non-smoking pack, side & lane assist, reversing camera, storage & luggage pack, tech pack with audi connect, tyre pressure warning, towbar, variable headlight range control, xenon light pack
  4. #43
    Sep 2013
    135
    Quote Originally Posted by cemerson View Post
    It's probably becuase USB sticks come FAT formatted. You could always connect the HDD to a PC, dump the contents onto it's hard drive; reformat the USB HDD with FAT; dump the contents back on then it should work!
    Delivered on-time.
  5. #44
    May 2013
    3,255
    Yeh, lots of effort though
  6. #45
    snowfree52's Avatar
    Full LED baby !
    May 2013
    467
    for those wo wonder :
    A3 3-door TDI 184 Quattro Stronic Brilliant Red : Sline kit - Auxiliary heating - LED headlights - 18" 10-spoke rims - audi connect - magnetic ride - driver assistance package - side assist - rear camera + park assist - alcantara/leather seats - auto dimming mirror - panoramic glass sunroof - towing equipment - electric lumbar support - heated front seats - hold assist - high beam assist - advanced key - B&O sound system etc
    Tuning box DTUK, 235hp/480Nm
    1/4 Mile 13.84 @ 95.2 MPH
    Porsche BBK...
  7. #46
    Sep 2013
    East Sussex
    1,582
    Quote Originally Posted by NotquiteWelsh View Post
    FAT only supports a maximum volume size of 2gb, FAT32 supports 32gb, NTFS will support up to 2tb's...
    Now a proud owner of a A3 1.4 tfsi Saloon S-Line, 6-speed, Daytona Grey, Technology Pack, Comfort Pack, Cruise, Advanced Key, Privacy Glass, Audi Parking System Plus, Interior Lighting, Folding Door Mirrors, Light & Rain Sensor. Hold Assist.
  8. #47
    Oct 2013
    415
    Quote Originally Posted by cuke2u View Post
    This is incorrect... FAT32 limit is terabytes (depending on what sector size in use). NTFS can support over 2TB but not without a bit of jiggery pokery. The big limit with FAT32 is the 2G filesize limit which isn't important for audio but is for video. Claiming a hard cutoff is only possible if you know what is and isn't supported directly by the controller.
  9. #48
    May 2013
    3,255
    Back at work - my drive is NTFS unfortunately so can't test it. I don't see any reason why it wouldn't work though if it were FAT32.
  10. #49
    Oct 2013
    10
    I have a exfat formatted drive with about 60GB of music on it. It worked fine in my 2011 scirocco via the USB MMI cable but in the A3 it works for a couple of songs and then cant read the drive. At the same time it crashes the Navigation and Bluetooth auto streaming. I suspect the hard drive is pulling too much power causing the system to error out.
    Eventually the MMI resets/reboots and everything starts working again providing the hard drive is disconnected.
    I am going to order a 64GB USB Flash drive and see if that works better.
  11. #50
    Sep 2013
    East Sussex
    1,582
    Hi, yes the power demand is often the reason why some hard drives do not work. However, in some cases, it can also be the cable as well...
  12. #51
    Nov 2013
    Portlethen, Scotland
    115
    Just thought I'd give you an update on this.
    Bought a 500gb WD Elements HDD from Currys for £40, put some albums on it and tried it in the car. Not recognised Drive was NTFS so formatted as Fat32, put music back on and it works fine.
    Happy days thanks to all for help.
    Si.
    mjcourtney and cemerson like this.
    A3 S-Line 1.4 TFSI COD Manual in Glacier White with Comfort Pack including Park Plus, S-Line Sports Suspension and SD Card Based Sat Nav.
  1. New TV & DVD-HDD Recorder - Connections questions.
    By jdp1962 in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 3rd June 2007, 19:26
  2. HDD MP3 Player
    By stuarthodgson in forum In-Car Entertainment
    Last Post: 8th February 2005, 07:25
  3. CD Changer Connection in A3
    By necroeire in forum In-Car Entertainment
    Last Post: 20th January 2005, 16:25
  4. Removing rear panel - dodgy speaker connection ?
    By Masterm8fo in forum In-Car Entertainment
    Last Post: 15th September 2004, 13:36
  5. Arial connection
    By gburgess in forum In-Car Entertainment
    Last Post: 1st November 2003, 18:32
