Chris NottAH Fabrications
Results 1 to 9 of 9
    dieseldoug's Avatar
    Oct 2012
    Aberdeenshire
    240
    Stop/start issues
    My wife uses stop start every day, but she has had some issues lately with it not working but I have told her there are so many variables that it will not stop. But yesterday when I was in the car it worked perfectly at every stop until the last one wher the car would not restart. We had to start the car manually then we shut the system down. Contacted the dealer which will look at this on the 5th November
    Has anyone else experienced this issue not starting after stopping.
    Doug.
    A3, 2.0 TDI, S-Line, 6 speed manual, Scuba Blue, S-Line suspension, heated/folding mirrors, privacy glass, fine nappa leather, heated seats, light/rain sensor pack, flat tyre indicator, Purchased and supplied by Aberdeen Audi
    Sep 2013
    East Sussex
    1,571
    Possible sensor/switch on the clutch?
    Schizophonic's Avatar
    Jul 2013
    Northampton
    322
    What was the temperature set in the car? Was the air con on? To give the car a good test and no user error. Switch off the client control completely and driven the car as normal. If the stop/start fails to engage then it's a deal issue to look at.
    dieseldoug's Avatar
    Oct 2012
    Aberdeenshire
    240
    Car was at operaing temperature and working fine, we stopped at a round about the car stopped and started as normal, 30 meters after the roundabout we stopped at light crossing car stopped again and never restarted without us intervening and starting the car, then turned the system off.
    Sep 2013
    East Sussex
    1,571
    The temperatures would not prevent the car from restarting unless the engine had overheated, unlikely as the engine was off.
    Oct 2013
    Yep, my wife's A3 1.4 TFSI has had an intermittent non-restart issue with the stop-start facility since we bought it from new, March '11.
    Audi first claimed it was not a 'recognised' fault, then carried out remedial work under guarantee only for fault to return. The Audi dealership now claiming there is no fault!?! My vague observation is that it has something to do with cold engine and certain climatic conditions but I'm no expert...just want a car that works properly.
    It is so frustrating dealing with these people...our battle continues!
    BTW...a pressure sensor was replaced to no avail....would be really interested to hear how your dealership resolves the issue.
    snakehips's Avatar
    Aug 2013
    North Herts
    614
    Curious to know what % of fuel economy is accounted for by start-stop? The more I read about it the more I think I will permanently disable, especially as fuel economy isn't a priority anyway.
    A3 SB S-Line TDi 184PS Quattro S-tronic. Shiraz Red, Tech Pack, Comfort Pack, B&O, Sunroof, LED lights, lots of other stuff.
    May 2013
    3,249
    Mine has worked great every time. I think they say 3% savings on average, but put it on the mpg display and watch you rmpg go down and down while sitting in traffic with the engine on... depends on the kind of journey you do.
    Sport 2.0 TDI 150 Sportback in Scuba Blue, alcantara/leather, advanced key, audi sound system, comfort pack w/ ACC and park assist, deselect sports suspension, auto-dimming & folding door mirrors, electric lumbar support, heated seats, hold assist, non-smoking pack, side & lane assist, reversing camera, storage & luggage pack, tech pack with audi connect, tyre pressure warning, towbar, variable headlight range control, xenon light pack
    Sep 2013
    East Sussex
    1,571
    From my experience of a start/stop system I have found that if you only perform short journeys then the battery will fall below the level needed for the start/stop to work. Also if the outside temps are too hot or cold and you have the CC set high or low will also prevent it for working. One of the tests they do is to stall the car then press the clutch to see if it restarts...
  1. Anyone had Stop/Start issues?
    By Brownie78 in forum New A3/S3 (8V Chassis)
    Last Post: 6th August 2013, 21:24
  2. starting issues 1988 90 quattro
    By gav660 in forum General Technical / How To
    Last Post: 10th April 2007, 11:00
  3. Cold Start Issue......?
    By cliveywolves in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2007, 14:48
  4. Cold start issues? Maybe it;s your O2 sensor.
    By eddyg in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2006, 02:03
  5. 1.8 SE intermittent starting issue
    By easytease in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd February 2006, 09:42
