Volks AutosJMB Retrofits
Results 1 to 9 of 9
    May 2013
    Bristol, UK
    77
    Annoying Road Noise
    Lately, at certain speeds of around 50-60mph, and only at certain times, there is wind noise that seems to come from the passenger side door and the door at the back on the same side. I'm sure it has not always done this and was always pleased with the lack of road noise.
    I have checked the doors are definitely shut and the windows are definitely all the way up so no idea what it causing it. Has anybody had the same?
    Jul 2011
    wiltshire
    137
    If its definatly wind noise it may be something as a non sealing door rubber,
    Sep 2013
    48
    Mines the same
    Dylock's Avatar
    Apr 2013
    232
    I had exactly that, it was one of the vents was open just a tiny bit causing the noise. Try fully closing or opening it and see if that makes a difference.
    May 2013
    Bristol, UK
    77
    Ah interesting. But I won't pretend I know where these vents are ......
    the he noise seems to from the right hand side window. It's as if the window is bit fully up. But it is. If it is the seal is it the sort of thing audi could/should fix?
    Dylock's Avatar
    Apr 2013
    232
    Sorry I should have been clearer, I mean the cabin vents. In my case it was the far passenger one which just open a tiny bit causing wind noise.
    May 2013
    Bristol, UK
    77
    Excuse my ignorance, but where are they?
    May 2013
    Bristol, UK
    77
    And I am assuming that you dont mean the main ones on the dashboard lol.
    Dylock's Avatar
    Apr 2013
    232
    That's exactly what I mean
  1. Road Noise A4 S-Line
    By GAC in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd June 2009, 22:29
  2. 3.2 owners, road noise
    By Damo S in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th May 2009, 23:24
  3. Tyres... The Road Noise! Ahhhh!
    By DPM in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th August 2008, 11:13
  4. A3 road noise question
    By sworks16 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd February 2007, 19:55
  5. Wind/road noise
    By V5Ade in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2003, 19:43
