AH FabricationsSky Insurance
Results 1 to 7 of 7
    Sep 2013
    No Entertainment Sound - Help!
    Hi,
    I'm from Newcastle in the UK. I have a new 2013 Audi A3 Sline Sportback 4 door (no jokes please about someone from Newcastle being able to afford a new Audi Sline ! :-)
    I got the 705 watt Bang & Olufsen Sound System fitted. This morning on my way to work I noticed the Entertainment sound is dead. No music at all from any sources. None of my MP3's will play. I flicked the "Radio" button and there was no sound for that either. I checked the volume and turned it up to 30 but still no sound. Definately not on mute.
    I checked my Bluetooth phone just to make sure that wasn’t interfering. I've used the Bluetooth audio many times to play songs from my phone. No sound from there either. I switched Bluetooth off all together in case that was causing a problem. I switched sources from Jukebox to SDCARD. No music will play at all. The tracks count up as if they are playing, everything looks fine but no sound.
    Strange thing is that all other sounds and beeps work fine:-
    - Sat Nav: I can hear the navigation instructions.
    - Reading Text messages / Emails: The "Read" function for text messages and emails works. I can clearly hear her voice.
    - The audio works for the parking sensors front and rear.
    - Telephone: The audio works fine for the telephone.
    - Beeps and sounds when configuring items work fine.
    It is just the volume for "Entertainment" that doesn’t produce any sound. i.e. when I rotate the volume control when in audio mode (media mode) the word "Entertainment Volume" appears on the screen but there is no sound.
    Perhaps the Entertainment System / Media System uses a separate amp? Maybe the Sat Nav, Telephone and parking sensors etc aren't connected to the main amp as they never need to be heard at 800 watts! Maybe the Bang & Olufsen sound system has it's own amy and all other sounds are played via standard amp?
    Audi garage cant do diagnostic until 7th October!! Dont want to tamper too much, just wondering if this could be a fuse (e.g. if the media system does use a separate amp perhaps it has a separate fuse?).
    Never play it very loud at all (apart from a few BOOOM BOOOM BOOOM demos when I first got it in May). But nothing past Vol 20 since.
    Would appreciate any advice.
    Many thanks.
    mjcourtney's Avatar
    Jan 2013
    South England
    1,039
    Have you tried resetting the MMI using the three key press?
    2013 8V Glacier White A3 Sportback 1.4 TFSI S-line Mnaual
    SE Suspension, Tech Pack, B&O, Comfort Pack, Electric folding mirrors, Park Assist, TPMS, Interior Light Pack
    97catalunya's Avatar
    Jun 2013
    Southend-on-sea
    546
    Quote Originally Posted by mjcourtney View Post
    That's the only thing I can think to try too, I would be surprised if the nav would use a dedicated amp?
    A3 S-Line 1.8TFSI S-Tronic Daytona Grey, Tech Pack, Comfort Pack, B&O, Parking System Plus with reversing cam, HHA, Folding Mirrors, Interior Lighting Pack, Advanced Key
    Nov 2012
    72
    Sounds like to me you have pushed in the volume button on the steering wheel which mutes the entertainment.
    I know you have said you have not but that is what it sounds like?
    Good luck.
    Jun 2013
    Southend-on-sea
    546
    Quote Originally Posted by Danny Fireblade View Post
    Good luck.
    Dose mute not get over ridden when you turn the volume back up?
    Nov 2012
    72
    Quote Originally Posted by 97catalunya View Post
    ill try in a bit and let ya know.
    Nov 2012
    72
    Okeedokee, when I pressed the volume rocker switch it muted it and reduced the volume to zero.
    If I then turned the rocker switch again it rose the volume from zero upwards.
    Hope that helps?
  1. REAR Knocking sound!!! HELP
    By Peterhendo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th April 2013, 22:01
  2. PS3 surround sound help
    By indiemike in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 1st October 2009, 12:55
  3. a3 sound help
    By zeeeebo in forum In-Car Entertainment
    Last Post: 4th August 2009, 14:14
  4. Alarm sounding - help needed!
    By nicklght in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2007, 09:11
  5. pc sound not working properly? Help
    By Dumpvalve1 in forum General Chat
    Last Post: 27th September 2004, 22:26
Tags for this Thread
