Sky InsuranceBadger5
Results 1 to 16 of 16
    Jan 2013
    33
    Exclamation IOS 7 Problem with MMI Bluetooth Interface
    I've upgraded my Iphone 5 to IOS 7 and the Bluetooth interface just stopped working...
    I can still browse my contacts directory and place/answer calls but you can only hear static noise from the speakers.
    Anyone else who has tried the above please confirm if you get the same behavior...
    thanks
    27,097
    1st remove the pairing from either or both devices, shut down the car, startup again & repair/test.
    If no go, then do a complete fresh IOS install, add a contact & test the sync/calls are working again.
    I ran an IOS 7 GM install few days before & didn't have much luck with BT, installed public release version yesterday (which was supposed to be identical to the GM, but wasn't) & fresh install seemed to allow me to see devices again, this was on an I4 btw.
    Jan 2013
    33
    I've tried removing the pair and shutting down the car (working in IT is my routine troubleshooting technique for pretty much anything that stops working :P :P :P )
    Sync was working normally no issues there , just audio problem.... i'll try fresh install ... (Also makes sense for IT people) :P :P
    thanks for your reply
    Jan 2013
    33
    i've reinstalled ios 7 and started from scratch with a new iphone setup. i still get static noise instead of audio.
    unless someone with the same car/ phone had more luck , i would advise against upgrading to ios 7 for the time being.
    smudger69's Avatar
    May 2012
    Sunny Scotland
    58
    Just been out and tested it with my i4s with ios7 and no issues.
    Jun 2013
    London
    183
    Upgraded my iPhone 5 to iOS 7 last night. Not actually tried making a call in the car with it since, however I did use Google Maps navigation this morning, and the directions came through the car speakers fine over Bluetooth.
    A3 8V 1.8T 6 speed 3 door S line - Daytona Grey. Interior lighting pack, privacy glass, comfort pack, electric folding heated dimming door mirrors, tyre pressure monitor, electric lumbar support, cruise control, acoustic parking system rear, B&O sound system.
    Jan 2013
    33
    thanks Tim I'll try to use the Bluetooth for music/audio redirection,to see if that works.
    In case you place a call let me know if it works.
    Vertigo1's Avatar
    Jul 2006
    2,624
    FYI, at present you can still go back to iOS6 if you want to. Just download the IPSW file from here then hold the shift key whilst clicking the restore/reset option in iTunes and browse to the file.
    This will only work until Apple stop signing/authenticating iOS6, which could happen at any time.
    Jan 2013
    33
    Quote Originally Posted by Vertigo1 View Post
    You are absolutely correct , already downgraded... Unfortunately tinyumbrella wont work on iphone 5 so there is a narrow time window in case someone wants to switch back to ios6.
    stevependleton's Avatar
    Nov 2012
    Nottinghamshire
    13
    Upgraded my iPhone 5 last night and noticed that Bluetooth was turned off on the phone after installation and set up. Bluetooth working normally with the phone in the car today. Sorry to hear of your problems drtav13.
    A3 Sport 8v 1.4 TFSI Monsoon Grey
    Jun 2013
    London
    183
    Quote Originally Posted by drtav13 View Post
    Made a trial call this evening and it was fine. Maybe your car needs a software update to be compatible with iOS 7?
    May 2013
    3,228
    It shouldn't need to be 'compatible' with a particular OS - the bluetooth protocols are published standards, which are up to the mobile phone to implement rather than the car, so as long as iOS7 implements them correctly (which is very much NOT a given...) you should have no problem
    Sport 2.0 TDI 150 Sportback in Scuba Blue, alcantara/leather, advanced key, audi sound system, comfort pack w/ ACC and park assist, deselect sports suspension, auto-dimming & folding door mirrors, electric lumbar support, heated seats, hold assist, non-smoking pack, side & lane assist, reversing camera, storage & luggage pack, tech pack with audi connect, tyre pressure warning, towbar, variable headlight range control, xenon light pack
    Aug 2013
    136
    Not had any issues with my 4S in the A1
    Vertigo1's Avatar
    Jul 2006
    2,624
    Just put iOS7 on my 4S this afternoon but not re-paired it with the car yet. I don't stream music from it anyway as I have a dedicated iPod touch in there for that.
    Vertigo1's Avatar
    Jul 2006
    2,624
    Out of interest, have you tried resetting the MMI? Press Menu, the wheel and the top right soft-button together.
    Jan 2013
    33
    Unfortunately I wont be able to do more tests , since im back on 6.1.4 . Apple has stopped signing IOS6 ,so in case I go to IOS7 I wont be able to downgrade the phone again.
    On the apple support forum I've found a couple of things to try
    1) reboot both car AND Iphone before trying a new pair
    2) remove apostrophes from the iphone's name . (by default iphones get "yourname's Iphone" which for some reason creates problems in IOS7 and Bluetooth.
    I will try again after Audi's Phone Database has been updated to include IOS7 (currently it's on 6.1.4)
    Audi Datenbank f�r mobile Ger�te
    thanks for your tips guys!
  1. Problems with Bluetooth Install with RNSe
    By Shaun Burford in forum In-Car Entertainment
    Last Post: 13th June 2012, 19:44
  2. OBD2 wi fi? bluetooth? Interface that worked with the Iphone??
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd December 2011, 17:29
  3. MMI bluetooth problems- iphone??
    By trekbiker in forum In-Car Entertainment
    Last Post: 21st July 2011, 14:50
  4. Problem with MMI system- HELP
    By grim ree in forum In-Car Entertainment
    Last Post: 3rd May 2010, 09:41
  5. mmi initializing problem with iPod
    By glens14a in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th October 2009, 11:33
