Had assumed tyre pressures would be at nominal when I collected 2 weeks ago and only checked them today, after 300 miles so would not expect them to have changed much since I picked the car up.
Have 18" and fronts should be around 38 -40 psi and were inflated to only 32psi and rears were at 33psi and nominal is about 40 - 44psi, better low than too high but disappointed that the dealer did not check these as part of PDI
Not sure if anyone has had this , but if you have only recently collected and not checked your tyre pressures might be worth giving them a quick check.
