Badger5Volks Autos
Results 1 to 33 of 33
Like Tree2Likes
  • 1 Post By dkpeter
  • 1 Post By Richyboyp
Thread: drive select
    Jun 2013
    Trinidad W.I.
    133
    drive select
    hi all,
    Is there anyway to jump from auto to dynamic and dynamic to auto directly?. I usually use the drive select switch and going from auto to dynamic is simple, but to return to auto i have to cycle through the other modes.
    Using the mmi just takes too long and requires too much attention.
    I dont like leaving it on dynamic since the revs are too high, esp when following a slow car for some time.
    When I get a small window for overtaking i need to get everything out of the car and therefore jump to dynamic for the pass.
    It would be nice to have a dedicated 'dynamic mode' button like 'sport button' on bmws.
    May 2013
    3,223
    Surely if you put your foot down in auto it does the same as dynamic anyway?
    Sport 2.0 TDI 150 Sportback in Scuba Blue, alcantara/leather, advanced key, audi sound system, comfort pack w/ ACC and park assist, deselect sports suspension, auto-dimming & folding door mirrors, electric lumbar support, heated seats, hold assist, non-smoking pack, side & lane assist, reversing camera, storage & luggage pack, tech pack with audi connect, tyre pressure warning, towbar, variable headlight range control, xenon light pack
    Jun 2013
    Trinidad W.I.
    133
    no since in auto the car might be in 6th or 7th when cruising behind the slow car and there will be a delay when i kick down unlike dynamic where it will be high revving in 3rd ready to attack.
    I guess i will have to just drive the car manual...I still think dynamic mode could be a bit more sensible with the high revs.
    Flode's Avatar
    Apr 2013
    9
    Have you tried to slide it into sport mode?
    Jun 2013
    East Sussex
    462
    If Audi list the drive modes in the order on they are set up on the car, i.e.
    Comfort, Dynamic, Auto, Efficiency and Individual.
    then couldn't you set up Individual mode same as Dynamic, which just means a double press on the drive select button when in Auto would take you to Individual instead of 4 presses to get to Dynamic, which is just that little bit easier when you in a rush to over take.
    just an idea, as haven't got mine to test yet, but if there is not a better way to do could be an easy compromise to sort.
    A3 sport back, Misano Red, S Line, 1.4 C.O.D. Manual, Panoramic Sunroof, Audi sound system, Folding mirrors, Interior lights pack, Non smoking, Delete Badges, Sports suspension, Hill hold & 2 year servicing & 4 year warrantee.
    Richyboyp's Avatar
    Aug 2013
    Stoke on trent
    156
    What I do: my car is normally in efficiency mode and so like you the gears are wrong for power. Kick down does work well though if I'm honest. Do if I want to change to dynamic I just pull back on the selector which then puts it in 'sport' I just assume this is dynamic although someone may say otherwise. Once I've overtaken I then pull selector back and it returns to E. now I assume if you are in 'auto' this is what it would return to but not tried as I always run E. other option is push selector to the left and manually change gear, that's also fun.
    Hope this helps
    A3 S Line 1.8 TFSI Quattro S Tronic
    Brilliant Red, Acoustic parking, Adaptive/Xenons plus, Advanced Key, B&O, Comfort pack, Door mirrors, Interior light pack, Privacy Glass, S Line sports suspension, Tyre Pressure Monitor, SD SatNav
    Happy days
    Richyboyp's Avatar
    Aug 2013
    Stoke on trent
    156
    Obviously pulling the selector back is while the car is in D.
    Happy days
    97catalunya's Avatar
    Jun 2013
    Southend-on-sea
    546
    I just use the paddles when I want to overtake. Just pop it down a gear or 2 overtake then hold the right hand up paddle for a couple of seconds and it returns to auto or just leave it and after a period of time it will switch back to auto it's self.
    A3 S-Line 1.8TFSI S-Tronic Daytona Grey, Tech Pack, Comfort Pack, B&O, Parking System Plus with reversing cam, HHA, Folding Mirrors, Interior Lighting Pack, Advanced Key
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,885
    This maybe a really stupid question, but is drive select only available on s-tronic models?
    2013 AUDI A3 SB S-LINE : 2.0 TDIQ 184 : GLACIER WHITE :
    : S-TRONIC : COMFORT PACK : SD SAT NAV : FOLDING MIRRORS : HEATED SEATS: RIGID BOOT LINER :
    Richyboyp's Avatar
    Aug 2013
    Stoke on trent
    156
    Think it's se and above ????
    Happy days
    May 2013
    3,223
    No, available on everything I think (can't remember about SE though, could just be Sport trim upwards)
    May 2013
    3,223
    Configurator says Sport upwards, so on everything except SE models
    Richyboyp's Avatar
    Aug 2013
    Stoke on trent
    156
    Oops! I was wrong sorry
    Happy days
    Apr 2013
    23
    A bit easier than using the drive select switch is to assign this functionality to the programmable steering wheel button. This enables you to toggle through the different modes with both hands on the steering wheel. Not exactly what was requested but perhaps a bit easier.
    Fragup likes this.
    Jun 2013
    Southend-on-sea
    546
    Quote Originally Posted by dkpeter View Post
    I have done this too, shame it can't be used as a shortcut directly to dynamic mode though.
    Jun 2013
    Trinidad W.I.
    133
    This sounds better, how do you go about programming the button?
    RossR's Avatar
    Apr 2013
    490
    It's under car settings in the MMI.
    Richyboyp's Avatar
    Aug 2013
    Stoke on trent
    156
    Was going to suggest the button on the steering wheel but not sure if that button is across the models and I also knew it only toggles through not just selects one driver style
    Happy days
    JohnnyM100's Avatar
    Jan 2013
    Hampshire/Surrey border
    461
    Sounds as close to a "push to pass" or "overtake" button as can be expected. Ace!
    Enjoying my 8V
    Daveotto's Avatar
    Mar 2013
    Hertfordshire, UK
    906
    Quote Originally Posted by 97catalunya View Post
    you sort of can if you leave it in automatic the next option in the cycle is dynamic
    A3 Sportback 2.0TDI S-line, - Daytona Grey, comfort pack, interior light pack , aluminium roof rails, Audi speakers, folding door mirrors, hill hold, sport suspension, no smoking pack.
    Aug 2013
    89
    Quote Originally Posted by Richyboyp View Post
    Yes, thats right if you just pull the selector back it goes into s-mode if you pull back one more time you are in normal mode again. however this will only change the gear selection and acceleration to normal s-mode but it will not change the chassie and also not change the steering etc to dynamic.
    Regards,
    Tom
    Jun 2013
    East Sussex
    462
    that's a cool feature, didn't realise you could do that. Bonus !
    Jun 2013
    Trinidad W.I.
    133
    Quote Originally Posted by Tom75 View Post
    Regards,
    Tom
    hi, when you say pull back , do you really mean to the side so as to engage the + - manual shifting in sport mode? or is there actually another notch down when in D that takes you to automatic sport mode?
    Aug 2013
    89
    Quote Originally Posted by karlabdool View Post
    No, not to the side because then you will be in manual sport mode. In the normal D position just pull it a little back and you will see in the display that the D disappears and a S shows up.
    Regards,
    Tom
    Apr 2013
    97
    Yes, but just to clarify for karlabdool - unlike the separate "S" position on the 8P s-tronic selector, this is just a case of moving the selector backwards and then releasing it. As it's spring-loaded it will return to the "D" position, but the box will be in "S" mode until you do the same again.
    Audi A3 Sportback Sport 1.8 TFSI S-Tronic, MY14, Scuba Blue, 15-spoke 17" alloys, Comfort Pack with ACC, Interior Lighting Pack, Audi Sound System.
    Aug 2013
    89
    Quote Originally Posted by constvoid View Post
    exactly
  28. #27
    Jun 2013
    Trinidad W.I.
    133
    Regards,
    Tom
    great this should work fine, better than cycling through the drive modes...but one question, when in auto drive select mode and cruising slowly(50-60 kmph) in D6 or D7, if i go to dynamic the car will downshift to S3. Will this downshift happen when i 'pull back'? or will it remain in the same gear(S6 or S7).
    Will try it today if i get the time.
    thanks tom
  29. #28
    Richyboyp's Avatar
    Aug 2013
    Stoke on trent
    156
    It will down shift right away. Same as dynamic. And pretty sure when pulled back again it will revert to what drive select you were in originally. I use this all the time
    karlabdool likes this.
    Happy days
  30. #29
    Jun 2013
    Southend-on-sea
    546
    I have been using "Dynamic" a little more now as the miles are building up.
    I have noticed when I change to dynamic obviously the gearbox will go into sport mode. But after leaving the car then getting back in when I start it up the gearbox is in D not S even though the drive select is in "Dynamic"
    Is this normal, I don't know if its just protecting the engine as it is still cold? If so does it automatically go back into S when warm?
  31. #30
    Toadoftoadhall's Avatar
    Feb 2013
    UK
    298
    On the subject of drive select, what are all the possible settings when programming the individual mode? on an S3 test car last week I did have a quick look but cannot recall all the customisable options. I know that the steering was one, engine sound another (though is that S3 specific?) what about the shift points of the s- tronic ?
  32. #31
    May 2013
    3,223
    Throttle, ACC, Cornering light (god knows what that does), Steering on mine I think
  33. #32
    Feb 2013
    UK
    298
    Quote Originally Posted by cemerson View Post
    Thanks for that. ACC - you mean the adaptive cruise? What setting options for that - the follow distance?
    From your sig info, looks like yours is Manual.
    Can anyone out there let me know about the s tronic settings and what can be adjusted within Drive Select?
  34. #33
    May 2013
    3,223
    Yeh, adaptive cruise. Not really played with it much but I assume dynamic will stick more closely to the speed or the car in front, and comfort is a bit more relaxed about it
  1. Audi Drive Select help please
    By golfather1 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 6th August 2012, 14:24
  2. Replies: 0
    Last Post: 11th August 2011, 18:19
  3. A4 Allroad and Drive Select????
    By huggis in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 18th February 2011, 18:42
  4. Audi Drive Select
    By diesebora in forum The Welcome Section
    Last Post: 17th October 2007, 19:33
  5. Audi Drive Select
    By diesebora in forum A5/S5/RS5 Forum
    Last Post: 17th October 2007, 04:51
