Sky InsuranceJMB Retrofits
Results 1 to 13 of 13
    Sep 2012
    64
    Using Apple Maps with AMI
    Found a really interesting feature in my friends BMW 3 Series (2012 Model) today.
    When connected to his phone (iPhone via bluetooth) and he is using navigation apps like Apple Maps the voice is played through his car sound system even if music is playing through the system (via local media or the phone). When a direction is said aloud the music volume drops and the direction is given and then simply reverts back to the previous media. On his system it appears as if someone has called him when the directions are spoken.
    I wanted to know if something like this is possible using the AMI system? I know if your playing music via bluetooth (on iPhone) and then have sat-nav running it will speak through the sound system but is this possible when your playing local media? i.e. iPod or SD card?
    62 A3 (8V) S-Line | 2.0TDI | Amalfi White
    Feb 2013
    103
    I was using Google Maps on the iPhone (via Bluetooth) and the directions were coming through the sound system. It was rather annoying because I'd rather listen to the music!
    Not too sure what you need to do to get it to work but it is possible.
    97catalunya's Avatar
    Jun 2013
    Southend-on-sea
    546
    Not tried it with the audi but I should think if you connect your iPhone via bluetooth for music instead of plugging it into the AMI, start your music playing on the phone and run the satnav app of your choice it should work.
    At least that's how I used it on my old car
    A3 S-Line 1.8TFSI S-Tronic Daytona Grey, Tech Pack, Comfort Pack, B&O, Parking System Plus with reversing cam, HHA, Folding Mirrors, Interior Lighting Pack, Advanced Key
    Aug 2013
    137
    This works fine in my A1 not tried it with apple maps though will try latter.
    I use the Navigon sat nav app and its a feature you can turn on and off.
    it can be a bit of a pain if you are trying to listen to a track but have lots of directions being spoken
    Sep 2012
    64
    Just wanted to mention it doesn't have to be 'Apple Maps' it can be any satnav application.
    Quote Originally Posted by 97catalunya View Post
    Yes I can confirm this does work, but its not quite what I want.
    I want to be able play music from another source to the satnav directions
    Aug 2013
    137
    Quote Originally Posted by vimy View Post
    With navigon you can listen to any source, it just cuts in as if you are on a mobile call and switches back at the end of the instruction.
    Schizophonic's Avatar
    Jul 2013
    Northampton
    322
    I used this for Google maps on my Android and worked through the speakers of the bluetooth
    Sep 2012
    64
    Quote Originally Posted by yetirider View Post
    Is this the case with any other satnav app?
    I've tried tomtom, apple maps and google maps, none of work through the Bluetooth without switching to the mobile as the source.
    Sep 2012
    64
    I've downloaded navigon and tested, it doesn't work through speakers either (when not using iPhone as music source)
    Sep 2012
    64
    Anyone else got any ideas?
    Jun 2013
    Southend-on-sea
    546
    I should think it will only work if using your iPhone as the source
    Sep 2012
    64
    I think so too :-(
    Apr 2013
    SouthWest
    54
    This is a function of the iPhone, it works the same way in the Civic
    2013 A3 SB 2.0TDI S line, Dakota Grey, Half Leather, Sports suspension, SD card Sat Nav, Cruise control, DAB radio, Audi sound system, Through-load facility, Hold assist, Heated front seats​
  1. A few issues I could use some help with.
    By eightrac in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th October 2009, 08:04
  2. Can you use iPod controls with Connects2 iPod connector
    By WildBruce in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2009, 10:05
  3. Buying used S3's with MTM conversions etc?
    By S3IZZO in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st March 2007, 09:07
  4. Used HRE 547 with PZero Rosso tires
    By ricky123hk2002 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 27th November 2006, 04:22
  5. Used HRE 547 with PZero Rosso tires
    By ricky123hk2002 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th August 2006, 12:25
Tags for this Thread
