Has anyone tried loading this yet? Is it good? Do you have to have the CD/DVD in every time you want to use it, or do you just load it once and then can use it from then on?
Perhaps its only on the tech pack. I got a CD (or DVD) inside the front cover of the MMI manual. I don't have an iPhone so can't use that app.
Yes I have, no it doesn't need the disc as it loads it into the system as you've put...Has anyone tried loading this yet? Is it good? Do you have to have the CD/DVD in every time you want to use it, or do you just load it once and then can use it from then on?
@The Challinor
Your dealer should have loaded in the Onboard Owners Manual for you as part of the Handover
Would a bear have loaded the manual then?
Or do you mean "bare minimum"
