Volks AutosAH Fabrications
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By mjcourtney
Thread: Difference between drive select / damper specification
    Aug 2013
    89
    Hi all,
    have a friend who is also planning to order an A3 1.8 TFSI and out of interest I would like to know what actually the difference is between the different drive select / damper specifications that are available:
    2H0 Without "drive select"
    2H1 "drive select"
    2H2 Controlled shock absorption magnetic ride
    2H3 Controlled shock absorption magnetic ride (sports)
    2H4 Driving profile selection and hydr. damper control
    2H5 Driving profile selection and conventional shock absorber
    2H6 "drive select"
    2H7 Drive select and magn. damper
    For example if you have only "drive select" without magnetic bumpers / magnetic ride how does this affect what you can control etc.
    Or what is for example the difference between "Drive select and magn. damper" and "Controlled shock absorption magnetic ride". Is the first option a magnetic damper but without magnetic ride?
    Regards,
    Tom
    mjcourtney's Avatar
    Jan 2013
    South England
    1,041
    Where did you find all those options? The only ones listed in the UK brochure are 2H6 (Drive Select) and 2H7 which adds Audi Magnetic Ride.
    2013 8V Glacier White A3 Sportback 1.4 TFSI S-line Mnaual
    SE Suspension, Tech Pack, B&O, Comfort Pack, Electric folding mirrors, Park Assist, TPMS, Interior Light Pack
    snakehips's Avatar
    Aug 2013
    North Herts
    606
    As far as I am aware, drive select only affects throttle and steering.
    A3 SB S-Line TDi 184PS Quattro S-tronic. Shiraz Red, Tech Pack, Comfort Pack, B&O, Sunroof, LED lights, lots of other stuff.
    RossR's Avatar
    Apr 2013
    490
    Quote Originally Posted by snakehips View Post
    It affects quite a few things, but I think the rest are all optional extras (except for climate control). One of the optional extras it will affect is magnetic ride. If you don't have magnetic ride it doesn't affect suspension.
    That's my understanding anyway. No idea what all those option codes are.
    Aug 2013
    89
    Yes, it affects different things.
    These options are taken from an excel file which includes all the possible options but I don´t know where my friend got it from.
    I have for example this
    and it would be interesting to know what the difference is compared to the other options with magnetic dampers.
    My friend came up with this list in the first place because he is thinking about what to order.
    Regards,
    tom
    Daveotto's Avatar
    Mar 2013
    Hertfordshire, UK
    906
    Are all of these codes really customer selectable options or just internal codes for the internal workings of the car which need to be set depending on the couple of options you can choose and the level of trim you have selected?
    A3 Sportback 2.0TDI S-line, - Daytona Grey, comfort pack, interior light pack , aluminium roof rails, Audi speakers, folding door mirrors, hill hold, sport suspension, no smoking pack.
    mjcourtney's Avatar
    Jan 2013
    South England
    1,041
    Quote Originally Posted by Daveotto View Post
    I suspect you're right. For example: If you ordered a Sport suspension with Drive Select (2H6) and Magnetic Ride (2H7) then I think the factory would add "2H3 Controlled shock absorption magnetic ride (sports)" in the background. Equally if you didn't specify magentic ride they would add "2H5 Driving profile selection and conventional shock absorber".
    The only user selectable options that I can see are 2H6 and 2H7, and unless you're advised by your dealer I wouldn't worry about the others.
    Tom75 likes this.
  1. 8P dampers - differences between models/part numbers?
    By munchkincoupe in forum Parts Requests
    Last Post: 6th September 2011, 14:04
  2. Replies: 0
    Last Post: 11th August 2011, 18:19
  3. engine differences between S3 and 1.8TQ
    By JamesA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th April 2004, 09:01
  4. Differences between 1.8 T Sport and Quatro (Looks)
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2004, 20:45
  5. Difference between 210 and 225 S3s
    By barl in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th August 2003, 22:06
