Volks AutosChris Nott
Results 1 to 9 of 9
    May 2013
    Cooling fan after-run
    Got a 2.0tdi SB manual with just under 3k on the clock and had a strange experience with it yesterday. Just wondering if anyone has had the same.
    Came back after a 25 minute gentle drive in the cool evening, temperature gauge showing normal, 56mpg average (so very gentle!) and when I turned the engine off, the cooling fan kept running at a level that sounded like a Harrier about to take off. There was a very hot smell coming from under the bonnet and when I opened it, I got a waft of very hot air. I turned the engine on and off again and it stopped.
    Anyone had a similar experience or got any ideas?
    97catalunya's Avatar
    Jun 2013
    Southend-on-sea
    546
    There is another thread about this on here somewhere.
    It sounds like the car is cleaning the "Particulate Filter" fitted to the Diesel cars, it happens when you are not doing lots of motorway miles. I'm sure someone will explain how and why it works
    A3 S-Line 1.8TFSI S-Tronic Daytona Grey, Tech Pack, Comfort Pack, B&O, Parking System Plus with reversing cam, HHA, Folding Mirrors, Interior Lighting Pack, Advanced Key
    Feb 2013
    103
    Could be the Dirty Particulate Filter (DPF) burning off the soot particles
    DPF Technology < Owners area
    27,099
    Yes another 8V owner has had this & the dpf cleaning afaik only runs when the cars in use.
    I would try to find the other person who had the issue & maybe collaborate on finding a fault & talk to the dealers.
    May 2013
    Many thanks for the response. Found a great explanation from Vertigo1 - definitely the DPF. Wish I hadn't restarted the engine now!
    Jul 2009
    Cwmbran
    9
    Does it occassionally on my current A3 too (Black edition 59 plate)
    Aug 2013
    Ditto on my new A3 (about 3 weeks old). Only happens occasionally, but it's just so loud! Really freaked me out the first time!
    Sep 2013
    48
    Did it tonight on my brand new car .. Lasted 5 mins .. Stop start wouldn't work either
    Feb 2013
    249
    Yep mine too!
    I am now the very very proud owner of an A3 Sportback S-line 2.0 TDI Glacier white - panoramic sunroof and privacy glass!
    See ya Polo!!!!!!!!!!
  1. after run fan question
    By audi-a6 in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th May 2012, 10:06
  2. Cooling Fans Still Running ?
    By Studj in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd May 2012, 22:45
  3. After run pump and fans, not working.......
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st July 2011, 18:43
  4. S3: Unit that controlls cooling fans and over run water pumps
    By Plane in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2011, 18:06
  5. NewTurbo Fitted, possible after-run fan problem?
    By alex-qts in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th April 2010, 14:19
