Monster MotorsportBadger5
    Jun 2013
    Trinidad W.I.
    133
    Loose metallic jiggle noise
    I sometimes hear a loose sorta metallic jiggle noise Only if the windows are down and if I am driving on a bumpy road and next to a long wall or something to reflect the sound. I am not sure if it is coming from suspension or if this is trait of the dsg7 as I remember reading somewhere about a similar noise with this dsg when going over humps. Anyone else experience this noise? It sounds like it comes from the front left.
    I will jack it up and shake things up and do my own investigating, will send it back if it continues
    Schizophonic's Avatar
    Jul 2013
    Northampton
    320
    What engine you got?
    Jun 2013
    Trinidad W.I.
    133
    Quote Originally Posted by Schizophonic View Post
    1.8tfsi 7dsg se suspension, front wheel drive, hear it when going slowly, kinda hilly area, will test it more and try to record if i get it again.
  1. Metallic tapping noise with on/off throttle
    By Sam_ in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th July 2012, 06:37
  2. Metallic vibration noise behind dash?
    By sam4191 in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th July 2009, 01:38
  3. Metal noise? On Wheel Turn at low speeds. A3 '98 1.8Ts
    By portsA318T in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2007, 10:47
  4. 02 A4 TDi 130 - metal plate clapping noise applying the brakes
    By sinbadfury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th October 2005, 23:06
  5. Metallic noise when hitting potholes
    By benk in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th July 2004, 09:00
