Sky InsuranceJMB Retrofits
    Schizophonic's Avatar
    Jul 2013
    Northampton
    320
    Water channel in fuel tank
    Noticed this when I was washing my petrol cap, I take it that it channels through the other side and not into the tank?
    JohnnyM100's Avatar
    Jan 2013
    Hampshire/Surrey border
    461
    My A3 8L has a drain hole just below the fuel cap but still within the plastic/rubber mount. It drains into the wheel arch and not into the tank. If the drain is outside the filler cap then pretty sure it would do the same thing to avoid water & dirt contamination in the tank.
    Enjoying my 8V
  1. Fuel tank question....
    By Izzy1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th December 2009, 14:33
  2. Vacuum in fuel tank
    By russ g in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th December 2009, 22:21
  3. TDI fuel tanks verse Petrol fwd/awd
    By Tifun in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th September 2009, 20:19
  4. Fuel tank/warning/guage oddness
    By aragorn in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st August 2008, 15:54
  5. 2.5 TDI Quat won't start - electric pump in fuel tank help !
    By RogerTDI in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th July 2007, 10:41
