JMB RetrofitsChris Nott
Like Tree1Likes
  • 1 Post By Colin1973
Thread: Tyre pressure
    May 2013
    10
    Tyre pressure
    Hi, probably a silly question, but can anyone confirm if the audi tyre pressure option I ordered with my SB are compatible with the audi valve caps with tyre pressure monitoring from the following link https://merchandise.audi.co.uk/?page=shop&pid=3053
    andy2000 likes this.
    mjcourtney's Avatar
    Jan 2013
    South England
    1,039
    I'm assuming they mean they're only compatible with the more expensive Active-TPMS system that monitors actual PSI in each tyre via a sensor built into the valve cap. This system is available on other Audi models, but the current A3 TPMS is an in-direct method and just monitors pressure via rotational distance / drag through the ABS sliprings so it can detect a flat tyre. In which case I'd say no, the valve caps in the link won't fit the valves on the A3.
    2013 8V Glacier White A3 Sportback 1.4 TFSI S-line Mnaual
    SE Suspension, Tech Pack, B&O, Comfort Pack, Electric folding mirrors, Park Assist, TPMS, Interior Light Pack
    May 2013
    3,225
    It does say "The valve caps can only be used for wheels and valves which are fitted with the tyre pressure monitoring system.", and the option on the A3 is worded exactly like that one, so could be. You'd certainly be able to send them back if not.
    Sport 2.0 TDI 150 Sportback in Scuba Blue, alcantara/leather, advanced key, audi sound system, comfort pack w/ ACC and park assist, deselect sports suspension, auto-dimming & folding door mirrors, electric lumbar support, heated seats, hold assist, non-smoking pack, side & lane assist, reversing camera, storage & luggage pack, tech pack with audi connect, tyre pressure warning, towbar, variable headlight range control, xenon light pack
    mjcourtney's Avatar
    Jan 2013
    South England
    1,039
    True, but the valve caps on the A3 are totally standard, regardless of TPMS. So the fact that these caps state they are 'only for cars with TPMS' suggests the valves are 'special'. But as said, easiest way is to order them and send them back if they don't fit.
    Oh, and then let us know the outcome lol.
    May 2013
    Yorkshire
    I believe the A3 uses the ABS sensor to monitor the wheels rotational speed as mentioned above for the TPM system. As the tyre deflates it's diameter is smaller so the ABS sensor detects the change compared to the other wheels.
    You should not need the TPM valve caps for an A3 these ones should suffice and you save a couple of quid
    https://merchandise.audi.co.uk/?page=shop&pid=3093
  1. A3 3.2 tyre pressures
    By GARTHY in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2004, 11:04
  2. tyre pressures
    By carl310166 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2004, 15:46
  3. Tyre pressures
    By Stormcatcher in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2004, 08:39
  4. TYRE PRESSURES
    By wezhaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2004, 08:06
  5. Optimum Tyre pressures
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th May 2003, 13:37
