Chris NottAH Fabrications
    spirosdimos's Avatar
    Mar 2013
    Athens
    27
    Question tyre pressure....OEM
    i want to know how complicate is too put oem tyre pressure and how does it cost.... (the car came in my hand yesterday)
    26,762
    Depends if your abs module etc supports the enabling as I suspect audi have fitted compatible parts already, you'd have to try enabling if vcds is upto date enough to see the bits to enable.
  1. A3 3.2 tyre pressures
    By GARTHY in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2004, 11:04
  2. tyre pressures
    By carl310166 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2004, 15:46
  3. Tyre pressures
    By Stormcatcher in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2004, 08:39
  4. TYRE PRESSURES
    By wezhaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2004, 08:06
  5. Optimum Tyre pressures
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th May 2003, 13:37
