Chris NottEM Tuning
Results 1 to 25 of 25
Like Tree2Likes
  • 1 Post By h5djr
  • 1 Post By jet_andy
Thread: halogen lights with drl
    Jun 2013
    Trinidad W.I.
    133
    anybody with a pic of what this looks like on the 8v a3?
    Feb 2011
    187
    Does it exist?
    1.4 TFSI 122ps A3 SportBack. Comfort pack, Audi sound system, Daytona grey, SD Sat Nav, S line trim. Love it!
    Quote Originally Posted by viperfire View Post
    Does it exist?
    As Xenons are only standard on the S-Line and DRLs are a legal requirement it must exist.
    Dave R (h5djr)
    RossR's Avatar
    Apr 2013
    490
    I think I've seen them in real life but not photos. Looks as you would expect - a small rectangular area illuminated with a single halogen bulb.
    Apr 2013
    East Sussex
    157
    Headlights will be halogen, DRL probably just a standard 20W bulb.
    A3 2.0 TDI Sportback Sport : Scuba Blue : Xenon Light Pack : Technology Pack : Audi Sound System : DAB : Hill Hold Assist : Comfort Pack....
    and Sport Suspension
    Jan 2012
    1,837
    Its the circled light in my pic here -
    This is it in its dimmed state, will be somewhat brighter when the sidelights and fogs are off.
    Apr 2013
    East Sussex
    157
    I understood that DRL's have to go off altogether when side or headlights are switched on. Certainly my previous Peugeot had DRLs that were incorportated with the sidelight - had a 20W/5W bulb. DRL used the 20W, when headlights or sidelights were on only the 5W element lit.
    On the A3 with xenons the LED strip dims to become the sidelight.
    Jun 2013
    Trinidad W.I.
    133
    Quote Originally Posted by a6-chris View Post
    thanks a lot chris !, hard to get a pic of this online !....i know what are the fog lights, but what is the side light? is that what we call park lights in my country? or is the side light the turn signal (indicator) light?
    Apr 2013
    East Sussex
    157
    The DRL element is incoportated in the main beam bulb.
    The halogen headlights use the following bulbs:
    for high beam and DRL - H15 12v 55w/15w
    for dipped beam - H7 12v 55w
    for parking lights - W5W 12v 5w
    I think the DRLs are can to be switched off or dimmed when dipped headlights are used but I don't think they have to.
    Dave R (h5djr)
    Apr 2013
    East Sussex
    157
    Seems they do have to go off with other lights, see here
    Jan 2013
    105
    On mine with halogen headlights:
    DRLs use the low wattage filament of a dual filament bulb. The second filament is the headlamp main beam
    Side (parking) lights are separate bulbs in the same reflector as the DRLs
    DRLs go out if side lights are turned on.
    Side lights stay on when headlights are on (DRLs are off)
    A3 1.4 Sport, S-tronic, Monsoon Grey, Comfort Pack, DAB radio, Interior lighting pack, Front Rubber Mats, Model / Engine badge deletion, Service
    Quote Originally Posted by jet_andy View Post
    I think in the case of some Audi models they don't actually go completely off but do reduce in power and thus brightness. Certainly that is the case with my current 8P A3. I have xenon headlights and the LED DRLs stay on but at reduced brightness when I switch my headlights on. This probably only happens if the car has LED DRLs.
    As the Halfords item says...
    DRLs are connected so that they come on with your ignition and switch off when the vehicle’s lighting is switched on, unless they have a night styling function which reduces the light output for night time driving.
    Dave R (h5djr)
    Apr 2013
    East Sussex
    157
    The LED DRLs actually become the sidelights by reducing the brightness - you'll see if you put just sidelights on without headlights.
    Jan 2012
    1,837
    On the 8V I noticed that you can't switch them off in the MMI nor can you in VCDS as there is very very limited coding due to being a new model.
    When the light switch is set to sidelights, the DRLs dim as per my picture, when dipped beam is on, then they remain as sidelights (dimmed).
    When the light switch is off or in Auto, they are at their full brightness. I obviously didn't notice whether they dim on indicating tho.
    Vertigo1's Avatar
    Jul 2006
    2,624
    They do dim when indicating, as the 8P did. Also, whilst on the 8P the DRLs would instantly switch between high and low brightness when indicating, on the 8V they actually transition smoothly (although quickly) between the two brightness states.
    I've never really noticed, nor has anyone seeing my car because I never ever drive on just parking lights. No lights or dipped headlights. Parking lights are really just that, parking lights and should never be used on their own when driving. Personally I wish the manufacturers would take away the option for parking lights and give parking lights when the ignition is off and dipped headlights when the lights and ignition are on. It would stop silly people from driving around with just parking lights on thinking it's OK because they have put their lights on.
    jet_andy likes this.
    Dave R (h5djr)
    Jan 2013
    105
    In the halogen equipped cars the side lights and DRLs are separate bulbs - they don't dim, the DRLs go out altogether when you turn the sidelights on! Look at the actual bulbs that are on, not just the appearance
    Nor do the DRLs dim when you indicate -they just stay the same brightness (halogen equipped)
    Apr 2013
    East Sussex
    157
    h5djr - I totally agree. I don't either - was just pointing out how they work.
    I've seen idiots though, driving with 'sidelights' (reduced brightness LED DRLs or conventional sidelights) on in murky conditions, not realising that by putting on just sidelights they're actually less visbile from the front becasue the sidelights are not as bright as the DRLs.
    Years ago Ford had a feature that prevented you driving with sidelights on, if you put just the sidelights on you got a sort of 'dim dip' - the headlights would come on but at reduced power. I thought it was a great idea but they stopped doing it aftera while. (I'm talking in the 80's here btw!).
    Jan 2013
    105
    There was a period when dim-dip was going to be mandatory in UK. As it was only a few ever got it. A Rover 416 company car that I had was fitted with that system
    May 2013
    3,229
    Quote Originally Posted by h5djr View Post
    I really wish people would start calling them parking lights over here, then people might actually get a clue what they are supposed to be for!
    Sport 2.0 TDI 150 Sportback in Scuba Blue, alcantara/leather, advanced key, audi sound system, comfort pack w/ ACC and park assist, deselect sports suspension, auto-dimming & folding door mirrors, electric lumbar support, heated seats, hold assist, non-smoking pack, side & lane assist, reversing camera, storage & luggage pack, tech pack with audi connect, tyre pressure warning, towbar, variable headlight range control, xenon light pack
    Quote Originally Posted by Chelmersteve View Post
    Yes I remember having a car with the 'dim-dip' setup as well, but I cannot remember which car. Probably an Austin 1300 GT or a Triumph Dolomite.
    Dave R (h5djr)
    Vertigo1's Avatar
    Jul 2006
    2,624
    Quote Originally Posted by cemerson View Post
    What are they for though? Parking?
    I was always taught that side lights (front and rear) are so others can see you whilst headlights are so you can see where you're going.
    May 2013
    3,229
    Yes, usually for parking on a dark road, you can use the indicators to light them on one side to highlight it as an obstacle. Or if you are pulled over on a road waiting for someone (for example), you can leave the pakring lights on and headlights off to avoid dazzling people unnecessarily.
    Do you know any lorry drivers? If so, ask them about how easy it is to see cars with only side lights when there is spray on the road... I can tell you with lorries kicking up the spray that they do, when they try and change lane and there is a car there with only side lights on, they will NOT see you. This is why I don't understand why people don't drive with headlights on when there is spray on the road, even if it isn't raining. Asking for trouble, especially on the motorway!
    Apr 2013
    East Sussex
    157
    I never cease to be amazed at people driving under sidelights in poor conditions, crazy. Quite often you see the car before you see the sidelights are on anyway! It's simple - if lights are needed, then its dipped headlights.
    And don't get me started on rear fog lights...
    cemerson likes this.
  1. Facelift lights (with and without DRLs) on 8P1?
    By DervA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th June 2012, 10:29
  2. Hazard lights with a mind of their own and ESP issues
    By V.I.P_UAE in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2010, 13:29
  3. Facelift owners with DRL's, headlight question
    By Sem in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd September 2009, 11:22
  4. Halogen Bulb for DRLs
    By h5djr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th September 2007, 12:39
  5. Retrofit auto lights with coming home feature
    By pav767 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th December 2006, 18:52
