Chris NottVolks Autos
    May 2013
    Finland
    30
    MMI navigation, audio artwork question
    I have a new 8V with the MMI navigation package and Audi Sound System. I quickly discovered it can handle M4A encoded audio files straight out of iTunes on an SD card. Playback has been flawless, but I'm having a problem with artwork.
    All my music is *meticulously* organized in a \artist\album layout, and I have placed a folder.jpg inside each album folder together with the individual music tracks. But, some album artwork shows on the MMI display, while other albums just show the generic music notes icon. At first, I thought it might be X-Y size issue, so I checked a few of the jpg's because the X and Y pixel counts are not the same for every image. Most are around 500 pixels on a side, some are larger and some are smaller. Even one which was 400x400 pixels does not show, while one that is 500x500 pixels does. Does anyone know what restriction, if any, there are for these files? Is it a filesize limit? How can I get the artwork to show for all my albums?
    May 2008
    557
    There's a few threads on this already. If you do a quick search, it should come up with the goods.
    Artwork has to be embedded - there's a utility called mp3tag (I think) which will do the trick.
    2013 A3 Sportback 2.0TDi 150 S-Line - Daytona Grey, B&O, Comfort Pack, Interior Light Pack, SD Nav, Hill Hold Assist.
    2010 A4 2.0TDi 170 S Line | 2008 Golf GT Sport 140 | 2008 S3 | 2005 A3 2.0TDi 140 S Line | 2003 TT 225 | 1998 A4 2.8 Quattro
    May 2013
    Finland
    30
    Quote Originally Posted by hittchy View Post
    Thanks, I'll look into it, but I don't think any of my M4A's currently have embedded artwork (I don't believe iTunes embeds the artwork, it's saved in the database if I remember correctly). These are NOT tracks purchased from Apple, they are encoded by iTunes from ripped WAV files that I get from ripping software. The album artwork (folder.jpg's) is downloaded using a tool called Album Art Downloader. The fact that some artwork works, seems to indicate that my feeling is correct and the artwork is not embedded but read directly from the jpg.
    2013 A3 Sportback 1.4 TFSI S-tronic, Brilliant Black, Business Sport package, S-line suspension, 18" black "rotor" wheels and Conti 225/40R18 tires, S-line roof spoiler, MMI SD navigation, Audi Sound System, connectivity package, xenon plus headlamps and LED running lights, fog lamps, heated sport seats, aluminum interior trim package, polished window trim, twin chrome exhaust, heated mirrors, removable towing hook, engine block heater
    Apr 2013
    SouthWest
    54
    Just out of interest my demo car read the tags on the MMI from an SD card every time but the DIS was intermittent for the same track on different trips.
    May 2013
    Finland
    30
    I'm still no closer to solving this. Mp3tag does not seem to be working correctly with these m4a files, because it does not show any tags... even artist/album is empty. So I loaded up some albums in foobar2000, and I found that at least the first two albums I checked had embedded artwork. One of these two albums shows artwork on MMI and the other doesn't. So I exported the artwork and checked the size. The one that worked was 300x300 pixels, and the one that did not work was 953x953 pixels. Since I'm still not convinced the artwork has to be embedded, I removed the artwork from all tracks of both albums. I kept the folder.jpg in each folder, assuming that if the player looks for embedded artwork and finds it empty, it will fallback to looking for the folder.jpg. Now, after removing the embedded artwork, it's still the same... the first album show artwork while the second one does not. I've also tried resizing the bigger artwork down to 300x300 pixels and still nothing.
    I need to sleep on this and try to figure out what to try next...
  1. Audi MMI Sat Nav DVD question
    By 210_MIH in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th December 2013, 14:38
  2. Question for anyone using the 2009 MMI Navigation DVD
    By elan2s in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 7th April 2010, 13:30
  3. Question for anyone using 2009 MMI Navigation DVD
    By elan2s in forum Satellite Navigation
    Last Post: 7th April 2010, 11:16
  4. New Audi S3 audio/comms question
    By shau in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd January 2008, 22:23
  5. Basic audio question
    By HotSauce in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th July 2004, 22:13
Tags for this Thread
