EM TuningVolks Autos
Results 1 to 11 of 11
    Apr 2006
    571
    Itunes to SD card (MMI) question
    As I understand it from looking through the manual, the Audi MMI system doesn't support lossless audio encoding (ALAC or FLAC). Currently, all the music on my iMac is ripped in ALAC format into iTunes, so cannot be copied to an SD card for use in the car. Is there any solution to this ? Re-ripping everything to AAC is not an option, as the same music library is for home use too, nor do I want to have a duplicate of every file already ripped.
    It seems odd that Audi have chosen to only support lossy formats, given that they are far more computationally intensive than lossless coding.
    Jun 2007
    69
    Why not convert to AAC, copy to SD, then delete from iTunes?
    Apr 2006
    571
    Yes, that may well be the only option.
    Do you happen to know if the Audi MMI supports AAC VBR, which is the default iTunes Plus format ?
    Jun 2007
    69
    Certainly supports AAC up to 320kbps and I think VBR is ~270kbps peak. It also supports Apple's M4u or whatever the format is called!
    Zig
    Feb 2013
    81
    mfspen - I transferred my music from my computer to a 64GB SDXC card which I use in our A3 Sportback which works fine.
    I have checked to see what is used when ripping CDs into iTunes and it comes up with the following:
    Import using: ACC Encoder
    Setting: iTunes Plus
    Details: 128 kbps (mono) / 256 kbps (stereo), 44.100 kHz optimised for MMX/SSE2.
    When I look in iTune the music files have a file extension of .m4a
    PjDali's Avatar
    Sep 2012
    Edinburgh
    169
    If you wish to use a lossless format the SD Card will play WAV files and copying album art as folder.jpg file into the appropriate folder with music files, the MMI seems clever enough to show album art.
    This format is not listed in the owners manual but worked for me as I tried a few formats out......
    A3 Sportback 1.4 TFSI Sport in Monsoon Grey with added extras - 5 arm 'kinetic' design wheels, comfort pack, audi sound system, storage and luggage pack, SD Satnav and Interior Light Pack.
    Apr 2006
    571
    Quote Originally Posted by Zig View Post
    Yes, those are the default settings for iTunes import, but I changed them to Apple Lossless when I ripped some of my CDs into iTunes. Having said that, 256k AAC does sound extremely good.
    Apr 2006
    571
    Quote Originally Posted by PjDali View Post
    Interesting solution.
    Do you manually have to move each album art jpeg to the same folder as the corresponding album, or can you put all the jpegs into one folder ? And what is the best way to do the copying, from within iTunes, or by copying the iTunes Music folder within Finder ?
    Zig
    Feb 2013
    81
    mfspen - It may be that ALAC is supported, both ALAC and ACC files have the file extension a file .m4a we need to try a SD card with ALAC files on it ot see if it is supported or not.
    PjDali's Avatar
    Sep 2012
    Edinburgh
    169
    Quote Originally Posted by mfspen View Post
    I have an old desktop PC which I still use Windows Media Player for ripping CDs onto a hard drive and I usually prefer to use the WAV lossless format.
    so all I did was copy the artist / album folder onto SD card which has the album art files as well as music files and surprisingly the A3 MMI could read files and play them fine.
    Never expected album art to display on car screen as you cannot embed any imagery into WAV file type but it worked fine.
    Might not be much diff in sound but I reckon WAV sounds a bit fuller over mp3 doing a direct listening comparison or maybe I just think it does as I know the mind can play tricks :-)
    sammi's Avatar
    verwood, Dorset
    346
    Follow sammi On Twitter
    we also use macs with the memory cards and i tunes its such an arse ! so wish we had an i pod in our s4! The best way i found unfortunately means to convert the songs you want first into the correct format, then create a playlist for all of this music, i know its a bummer having two types of music... if youre struggling for space get a time capsule!!! i then use i tune my walkman Download iTuneMyWalkman for Mac - Synchronize iTunes playlist to a mobile phone. MacUpdate.com it syncs nicely with the sd card and i tunes! I hope this helps!
  1. Replies: 33
    Last Post: 24th April 2014, 13:28
  2. Script to copy playlists from Itunes to SD Card for RNS-E for mac users
    By kolash in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th June 2012, 14:12
  3. Converting music from iTunes to sd card
    By S.line in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 30th December 2011, 15:56
  4. Door card sale question....
    By welshwoody in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd May 2011, 00:18
  5. Door card - lighting question
    By Lee_R in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th March 2011, 01:49
