Badger5Monster Motorsport
Results 1 to 7 of 7
    Mar 2013
    11
    Music off SD card
    So, if I use SD cards instead of my iPod - do I still get playlists etc?
    Jun 2007
    69
    If you create playlists on the SD Card, yes.
    Mar 2013
    11
    how do i do that?
    Jun 2007
    69
    Use a program like MP3Tag, you can select all the files on your card, then use it create playlists, which you then save to the SD Card. When navigating through the MMI, select playlists and it'll be there.
    May 2013
    3,249
    Can you play by folder as well?
    Nov 2012
    Belfast
    230
    by folder, by artist, by album, by playlist... I haven't bothered using my ipod in the car for music at all. 16gb SD fulfills all my needs.
    May 2013
    3,249
    Excellent - It's the same in my current car, I've just had a USB stick in there and used that the whole time. I've used the CD player in it once - to check it works!
  1. Album artwork off SD card
    By neil morris in forum New A3/S3 (8V Chassis)
    Last Post: 17th April 2013, 20:05
  2. MUSIC ON SD CARD
    By redleg in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 27th May 2010, 12:07
  3. How to transfer music onto SD Cards?
    By gaz j in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd December 2008, 18:39
  4. HOW DO I TAKE OFF DOOR CARD???
    By S3-Chris in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th June 2008, 15:01
  5. How do you take a door card off?
    By imported_Tariq in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th September 2004, 19:41
