Chris NottEM Tuning
Results 1 to 13 of 13
    Feb 2013
    Kent
    34
    2 weeks and need a new windscreen
    Picked up a stone chip that is to bad to repair apparently and need a new windscreen.
    Insurance company say they won't fit an Audi windscreen but will be like for like. I had a million questions on the colour of it I have the comfort pack which comes with the acoustic glass what is this though?
    Any help appreciated
    Zig
    Feb 2013
    81
    They would have to fit the same type of windscreen that comes with Comfort Pack. Which probably means they will have to fit a windscreen that is supplied by Audi or from the company that supplies Audi. Tell them that it is a special screen that is not fitted as standard but comes as part of an option. Also tell them the part number that is on the windscreen.
    _Zerocool_'s Avatar
    Jan 2013
    217
    If you have the rain sensing wipers make sure they put a brand new gel pack in with the new screen otherwise it messes it up
    Feb 2013
    46
    Hmm, just made me wonder, is the Comfort pack something you should declare to your insurer as an addition to the standard car? If you do not then is the, presumably more expensive, windscreen not covered per the small print on the policy?
    Will be interested to hear outcome
    Nov 2012
    West Sussex
    35
    That would depend on the exact questions asked by the insurer at inception, generally speaking factory fitted options do not need to be declared. If any doubt speak to your insurer.
    2013 A3 Sportback 1.4 TFSI Sport Phantom Black
    Zig
    Feb 2013
    81
    MiT
    MiT's Avatar
    Work Hard, Play harder!!
    Mar 2007
    Birmingham
    269
    as a reference when someone smashed my door window on my 8P audi, they replaced it for a like for like.
    what they did was replaced it from the same manufacture but just without the Audi logo. So it was from the same company who supplied it to audi.
    A3 Sportback 2.0 TDI S-Line
    Amalfi White || Comfort Pack || Audi Sound System 10 Speakers || Interior Light Pack || Elec Lumber Support || Sat Nav || Non Smoking pack
    number3's Avatar
    Nov 2012
    East Sussex
    335
    Quote Originally Posted by A3sportbackrob View Post
    you should be ok, check my thread , http://www.audi-sport.net/vb/new-a3-...97-gutted.html
    like it or not the may have to replace with audi screen!!!
    Audi A3 8v 2.0TDi S-Line, glacier white.
    Jan 2013
    107
    With the Comfort Pack your windscreen should also have a sunband across the top - make sure your replacement has as well
    A3 1.4 Sport, S-tronic, Monsoon Grey, Comfort Pack, DAB radio, Interior lighting pack, Front Rubber Mats, Model / Engine badge deletion, Service
    Feb 2013
    Kent
    34
    Quote Originally Posted by number3 View Post
    Thanks I am sure something like this will happen fingers crossed they realise this in time and not have to many repeat visits
    mjc
    Nov 2012
    33
    Same happened to me, two weeks old and bang!
    Explained to Autoglass when booking that the car was brand new A3 model with Comfort pack fitted, first fitter arrived with wrong screen (no grey band/acoustic glass), all worked out well in the end, genuine Audi screen with Audi logo ordered and fitted by Autoglass, nice tidy job.
    However, interested in the 'gelpack' comments above, the day after fitting I noticed a blob of gel seeping from the rear of the rain sensor fitting that had also dripped onto the cupholder/ashtray, I just presumed it was from the fitting process and just wiped it off. Might take a closer look later!
    _Zerocool_'s Avatar
    Jan 2013
    217
    MJC - see below for gel pack info
    Rain sensitive wipers
    mjc
    Nov 2012
    33
    Thanks for that _Zerocool_.
    Will have a good look at the sensor (both inside and out) later and also keep an eye on how it performs in rain.
  1. New to my S3 and need a new turbo, Should i go bigger??
    By jcramphorn in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th February 2013, 12:15
  2. May need a new windscreen - Auto lights
    By Wrath in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th March 2010, 19:21
  3. new and need black mk2 TT pics x
    By LisaMafia in forum The Welcome Section
    Last Post: 16th August 2006, 00:36
  4. New and need advice!
    By tenbucc2 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd May 2004, 03:38
  5. Im new and need Help
    By WannabeRacer in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd June 2003, 19:41
