Volks AutosBadger5
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Trebuchet
Thread: A3 SB 2.0 TDi something running when car off, hot, smell...normal?
    MiT
    MiT's Avatar
    Work Hard, Play harder!!
    Mar 2007
    Birmingham
    269
    Question A3 SB 2.0 TDi something running when car off, hot, smell...normal?
    So i have my new A3 SB 2.0 S-Line, i have done less then 50 miles (i think) so far, but i have noticed when the car is switched off something is still running (radiator fan i guess) and i can smell something, and it is hot under the bonnet. Smells like something hot is burning something or when something gets heating. hard to describe.
    Water is full to the max level.
    temperature on the gauge is 90 degree.
    Is this normal? (never had a new car before)
    Just wondering something is not as it should be.
    A3 Sportback 2.0 TDI S-Line
    Amalfi White || Comfort Pack || Audi Sound System 10 Speakers || Interior Light Pack || Elec Lumber Support || Sat Nav || Non Smoking pack
    Audi Man Dan's Avatar
    Sep 2012
    Cheshire
    55
    Quote Originally Posted by MiT View Post
    Hi Mit, this is the engine cooling fan after a regeneration cycle that stays on to cool down the DPF.
    Sep 2012
    Cheshire
    55
    Perfectly normal, usually will only come on after a shorter journey. Mine is 4 months old now, had the same concern myself.
    Jan 2013
    Cheshire
    96
    There will also be a bit on paint etc on hot surfaces like the exhaust manifold, turbo and block, that will burn off and "cure" over the first 100 miles or so. Perfectly normal.
    frazzeld's Avatar
    Oct 2012
    West Yorkshire
    136
    Mine was doing this until I gave it a good motorway run....hasn't done it since! "touch wood"
    Sep 2012
    Cheshire
    55
    Quote Originally Posted by frazzeld View Post
    A good blast on the motorway is advised with a diesel every 2 weeks. My particle filter light has only once lit up and the motorway run sorted it.
    __________________________________________________ _________________________________________________
    A3 8V - S-Line 2.0 TDI - Daytona Grey
    MiT
    MiT's Avatar
    Mar 2007
    Birmingham
    269
    Quote Originally Posted by Audi Man Dan View Post
    thanks
    Quote Originally Posted by Sootchucker View Post
    makes sense for the smell
    good to here, hopefully after the few trips of the next few days should sort it out then.
    thanks all for your comments, makes me feel better
    Appreciate it.
    Feb 2013
    57
    As above, as well as the short-term whiff you'll have whilst the exhaust us bedding in, you'll have the burning whiff from the particle filter regularly/permanently.
    diesel particulate filter (dpf) | AA
    MiT likes this.
  1. 1.9 Tdi Temps Running Cold(slow speed driving/city driving)
    By Eoghan in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th June 2014, 09:22
  2. TDi violent shaking when idle
    By nathanc in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th November 2010, 19:14
  3. 2001 51 A4 TDI SPORT MISSING WHEN IT RAINS
    By nafmughal in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st July 2009, 18:35
  4. A4 TDI 110 running temp?
    By rob1380 in forum General Technical / How To
    Last Post: 4th July 2007, 17:20
  5. lumpy idol,poor running when cold
    By mikechids in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th April 2006, 13:04
