Monster MotorsportEM Tuning
Results 1 to 7 of 7
    Jan 2013
    7
    Auto dipping kerbside mirror
    Hi all - quick question on the wing mirrors that hopefully someone can help with.
    I have the folding mirrors on my new A3 but thought there was supposed to be a function where the passenger side automatically dips when reversing so you can see the kerb. Mine doesn't do this - is there some way I'm supposed to activate this? Thanks!
    Apr 2006
    571
    If it's like the Golf, you have to make sure the adjustment switch is set to the 'L' position.
    number3's Avatar
    Nov 2012
    East Sussex
    335
    Quote Originally Posted by mfspen View Post
    do you not have to set it up first , as in move the mirrors to the dipped height you require, then it will always move to that height when reversing with the mirror knob switched to either left or right?, we are all different and may need it set at different heights, or do audi just set it when the cars being built?
    Audi A3 8v 2.0TDi S-Line, glacier white.
    Apr 2006
    571
    Quote Originally Posted by number3 View Post
    do you not have to set it up first , as in move the mirrors to the dipped height you require....
    Yes, quite possibly.
    In Golfs I have driven (Mk.6), it only works on the LH mirror, so if you set the knob to the middle or 'R' position, nothing happens.
    selar's Avatar
    Jan 2013
    Glasgow (buying in Edinburgh)
    161
    There's a bit of chat over in this thread here between people who have had it activated after purchase by VCDS. It would be good to get a be-all-abd-end-all confirmation on how this works, and whether the VCDS option is any different (maybe someone could make a video..? :-D)
    mjcourtney's Avatar
    Jan 2013
    South England
    1,041
    Yes it does require setting up before first use so that the system knows what height to set it to. The details are in the manual on how to set it up. Will try and dig them out later.
    Once calibrated it will dip in reverse but only when the mirror selection switch is on the left mirror setting (the 10 o'clock position). It will move back to normal height after you move forward above 5/10mph.
    Point to note: the dip settings are stored against the particular key you used to start the car. So if your partner is a different height they can use their key to open the car and it will use their settings to dip the mirror appropriately in reverse.
    2013 8V Glacier White A3 Sportback 1.4 TFSI S-line Mnaual
    SE Suspension, Tech Pack, B&O, Comfort Pack, Electric folding mirrors, Park Assist, TPMS, Interior Light Pack
    Dec 2009
    334
    Clever stuff
  1. Auto dipping reverse mirrors
    By max69vk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th May 2012, 15:59
  2. Auto Dipping Mirror
    By chuckys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2009, 23:08
  3. AUTO DIPPING MIRRORS
    By grey99 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th August 2006, 16:04
  4. Auto dipping rear view mirror - busted
    By marriedblonde in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th July 2005, 22:15
  5. Auto dipping rear view mirror. Retro fit.
    By imported_christhick in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th December 2004, 15:49
