AH FabricationsJMB Retrofits
    Nov 2012
    Belfast
    230
    Excessive engine fan noise
    Since yesterday I've noticed excessive fan noise from the car after the engine has been turned off.
    The temperatures here are around freezing and the noise has been after two relatively short journeys so I can't see why the engine would be running too hot.
    Its a 1.6TDI with only around 500miles on it. Has anyone else experienced this before I take it back to the dealer.
    May 2008
    557
    I get this regularly with my A4 after shorter journeys. Apparently it's normal and to do with the DPF. Fan runs on loudly for up to 10 minutes after leaving the car.
    2013 A3 Sportback 2.0TDi 150 S-Line - Daytona Grey, B&O, Comfort Pack, Interior Light Pack, SD Nav, Hill Hold Assist.
    2010 A4 2.0TDi 170 S Line | 2008 Golf GT Sport 140 | 2008 S3 | 2005 A3 2.0TDi 140 S Line | 2003 TT 225 | 1998 A4 2.8 Quattro
    Jun 2007
    69
    What Hitchy said, it's the engine cooling fans staying on to cool down the DPF after a regeneration cycle. The DPF get's to about 650c after a regeneration cycle, so it needs to cool down to avoid overheating the engine compartment. Nothing to worry about!
    Nov 2012
    Belfast
    230
    cool guys, thanks for clearing that up. Incidentally it was after switching the car into Economy mode - wanted to see what that was like for a while.
  1. Engine Fan
    By Audi-Max in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2008, 00:46
  2. engine fans
    By hilly123 in forum General Technical / How To
    Last Post: 19th December 2007, 22:04
  3. Any harm with excess engine oil?
    By catdog in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th October 2007, 02:56
  4. Engine Ticking Noise
    By Sm[]key in forum Diesel forum
    Last Post: 5th April 2007, 09:15
  5. Has anyone else had this ?? Engine fan not stopping
    By duncangoncalves in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st November 2006, 16:44
