Chris NottAH Fabrications
    Daveotto's Avatar
    Mar 2013
    Hertfordshire, UK
    906
    wheel size and performance
    Engineering logic tells me that if I have the same engine driving different sized wheels (not on the same car!!!) the performance will change. Things like 0 - 60, acceleration from 50 - 70 etc. etc. but I do not see different 0 - 60 values on s line compared to sport when one runs on 18"'s and the other on 17"'s. or is the engine mapping slightly different to accomodate
    Can anyone explain this? or provide any data on difference in performance when changing wheel size. Would be nice to think that under same settings a s-line is marginally quicker than a sport version. Or would I get better perforrmance if I changed my s line to 17"'s post delivery.
    Anyone got any insight on this.
    Dave
    A3 Sportback 2.0TDI S-line, - Daytona Grey, comfort pack, interior light pack , aluminium roof rails, Audi speakers, folding door mirrors, hill hold, sport suspension, no smoking pack.
    pjr
    pjr's Avatar
    Jun 2010
    Scotland
    56
    The rolling distances of the standard wheels, whether 16", 17" or 18" are all within a few mm of each other as the bigger wheels have lower profile tyres. While there are probably differences in the weight distribution between the wheel & tyre for the different sizes, it is probably small enough to not have an effect on acceleration etc.
    if you we're to fit wheels that had a smaller circumference e.g. 225/40 x 17 or 225/35 x 17 rather than the normal 225/45 x 17 then (I think) the acceleration would be slightly better, but also your speedometer would need recalibrated as the rolling distance would also have changed.
    Current - 2014 VW Golf GTI (220PS) - Tornado Red
    Previous - 2010 A3 1.6TDI Sport Cabriolet - Brilliant Red
    Jan 2013
    Cheshire
    96
    Plus the 18" alloys of the S-Line are machined with a new process called flow forming, (see extract below) meaning the inertia increase usually associated with larger alloys is reduced.
    "The optional 18-inch alloy wheels are no heavier than the 17-inch wheels; they are produced by a complex flow-forming technology. In this process, the rim well is rolled out over a cylinder under high pressure and at high temperature. The system shapes the wheel blank in a single work step, during which the material also becomes stronger. This permits thinner wall thickness's so that the wheel is both lighter and stronger."
    Daveotto's Avatar
    Mar 2013
    Hertfordshire, UK
    906
    Quote Originally Posted by pjr View Post
    Thats great...just done the maths and i reckon rolling distances are only about 15mm difference over the 16" - 18" rim range. That only leaves differences in contact area and how that affects power lay down and friction/resistance over the contact area (but my maths is not good enough to work that one out) and weight of wheels which (according to Sootchucker) is less for 18"'s so some advantage there.
    I am sure some smart group of folk at Audi know the answer but sounds like a good project for an engineering degree project to work out theortical differences.
  1. audi a4 avant (wheel size and lowering)
    By Neil Conlay in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th October 2011, 21:05
  2. Help with wheel size and tryes, going from 17" to 18" (pics)
    By Seaneylad in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th October 2010, 19:38
  3. Wheel size and fitment
    By djdougalno1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th February 2010, 08:39
  4. 19" wheels - offset and size query
    By Light Speed in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th January 2010, 19:48
  5. wheel size. and lowering
    By Adam-D in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st February 2009, 18:02
