AH FabricationsChris Nott
Results 1 to 8 of 8
Thread: Sat Nav App
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,402
    Follow Brodster On Twitter Add Brodster on Facebook
    Sat Nav App
    Hi guys. Didnt know which section to put this in as its either VCDS or thhis one.
    Customer of mine has bought a new A3 and has heard that to activate the sat nav it is something to do with an app that can be either purchased or downloaded. I have no idea what he was talking about but said I would enquire about it.
    Anyone got any ideas on this. Cheers
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    mjcourtney's Avatar
    Jan 2013
    South England
    1,041
    If the SD Sat Nav wasn't ordered from the factory then it can be added for around £500 direct from Audi. They supply the maps on an SD card, and then 'digitally authorise' the car to enable the Sat Nav functionality and accept the maps from the SD card. As far as i'm aware the only way to enable this is through Audi. If there is a way to do this 'unofficially' then be prepared for it to be disabled if it is ever plugged back into the Audi network at a dealer.
    Vertigo1's Avatar
    Jul 2006
    2,635
    Yeah I'd imagine Audi have made this pretty difficult to get around, i.e. not just a case of copying the SD card or even using VCDS as they know how prevalent those things are. I'm sure it can and will be circumvented but you're basically stealing by doing this and Audi would take a very dim view if they discovered it at any point.
    27,099
    To audi he goes Markus, as even if someone did crack the system, as soon as it went for a service or warranty work, they would probably disable it or invalidate some warranty, who knows, but I suggest going to audi.
    Brodster's Avatar
    Mar 2011
    Scottish Borders
    3,402
    Cheers peeps I will inform him and see what he does.
    Jan 2013
    33
    sdnav activation
    as you can see from ETKA the cost of the activation code is 200 euros , my stealership asks for 650 !!!
    I see listings on ebay around 230-300 euros , but the problem is that the code must be activated online by an audi dealer...
    Audi Steve's Avatar
    Mar 2013
    54
    Sat Nav App
    That is the sd card with data on and activation for the data only, you also need the 'function' activation as well at £250
    Vertigo1's Avatar
    Jul 2006
    2,635
    Yeah as Audi traditionally charge around that figure for an update set of maps on DVD (for cars which support this such as RNS-E and older MMI systems), I suspect that's just the price for a fresh set of maps on an SD card. It says activation but this is likely a case of activating the maps themselves rather than the nav system. It kind of makes sense that each set of maps would require a new activation otherwise people could easily copy the SD card. The older DVD based systems didn't have this, presumably as copying a dual-layer DVD was a fair bit trickier than copying an SD card.
  1. skobbler (i phone sat nav app)
    By A3ANDYF in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 1st December 2010, 08:31
  2. Sat-Nav and GPS Camera positions
    By mramage in forum Other Brands & Models
    Last Post: 8th August 2003, 14:34
  3. Sat-Nav System
    By Mo-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2003, 20:05
  4. Sat Nav
    By Nimo in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd April 2003, 23:45
