Results 1 to 14 of 14
    Audi Steve's Avatar
    Mar 2013
    54
    Vcds long coding helper?
    Does anybody know of any long coding help or even individual codes for the A3 (8V) just purchased VCDS any it works great on everything and even talk to new A3 ok but there is no data in the long coding help :-(, I'm after needle sweep (in dash 17) and front fogs as cornering lights (in on board power supply 09) maybe changing pim (pic in motion) speed to 255 as well :-)
    Jan 2013
    Cheshire
    96
    The needle sweep (or staging as VAG call it), is normally set in the adaptation channels. It's not part of the long code and therefore isn't a tick box par se.
    Audi Steve's Avatar
    Mar 2013
    54
    Has anybody done any coding or adaptions using VCDS on the 8V A3?
    Audi Steve's Avatar
    Mar 2013
    54
    Right just ran a full scan using VCDS on my A3 (8V) and the only systems it has picked up and will communicate with are as follows:
    01 Engine
    03 Brakes
    05 Start & Entry
    08 Air Con
    15 Air Bag
    16 Steering Wheel
    17 Dash
    19 Gateway
    2B Steering Column Lock
    42 Drivers door
    44 Steering
    47 DSP
    52 Passengers Door
    55 Headlight Range
    As you can see no
    09 Centrals Electrics
    5F Infotainment
    27,016
    Did you select autoscan or the specific 8V chassis?
    Mar 2013
    I have the same problem with my Audi A3 8V.
    - I selected the specific 8V chassis. Still no coding for 09 Central Electrics :-(
    27,016
    Show us your log aswell.
    Mar 2013
    Chassis Type: 5Q0
    Scan: 01 03 08 09 15 16 17 19 20 42 44 52 55 5F
    VIN: WAUZZZ8VXDA021825
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    20-High Beam Assist. -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    Address 09: Cent. Elect. (J519) Labels: None
    Part No SW: 5Q0 937 084 Q HW: 5Q0 937 084 Q
    Component: BCM MQBAB H H14 0106
    Serial number: 00011232701649
    Coding: 04000B46C20122FD03044000001C07A8000000000000000000 0000000000
    Shop #: WSC 06314 790 00021
    ASAM Dataset: EV_BCMCONTI 010001
    ROD: EV_BCMBOSCH_AU37.rod
    VCID: 4688FBA6F925362EF59
    No fault code found.
    When entering Coding in 09 Central electric and pressing Long coding helper, i get an error message saying that no coding helper is available.
    - I am trying to disable the Seatbelt warning chime.
    27,016
    Seat belt chime info is held in airbags 15 or instruments 17.
    Given the cars modules are new, the database is being created by RT at the moment, so if you want to create more logs for them to make up more module files, ping them an email to support@ross-tech.com, asking if they have your modules covered on next release or need some logs sent to them.
    Audi Steve's Avatar
    Mar 2013
    54
    Got to the bottom of it, you need to run the VCDS 12 beta, then picks everything up, belt chime is in dash (17)
    number3's Avatar
    Nov 2012
    East Sussex
    332
    Quote Originally Posted by Audi Steve View Post
    what else can you change ?
    Audi A3 8v 2.0TDi S-Line, glacier white.
    Audi Steve's Avatar
    Mar 2013
    54
    Not sure need to have a few hours to sort the rest out, I'm really after needle sweep, any ideas or what it may be called on VCDS?
    number3's Avatar
    Nov 2012
    East Sussex
    332
    have no clue sorry, NHN would know normally but his mentioned his not spent any real time yet on the 8v VCDS, I'd be to scared to change anything unless its in black and white on the screen lol , just in case I changed all the text to Russian !!
    Mar 2013
    Southampton
    23
    So I may be interested in having a play with this vcds system but I am wandering how difficult it is to understand and how expensive the kit costs? I know a lot about computing etc so I'm not completely daft but is there a previous knowledge needed or is it an easy plug and play system? New a3 sline 3 door glacier white due in April!!
  1. No Long Coding Helper Option
    By chris1988brown in forum VCDS (formerly VAG-COM) forum
    Last Post: 19th October 2012, 10:01
  2. long coding
    By Aspen in forum VCDS (formerly VAG-COM) forum
    Last Post: 27th April 2009, 21:27
  3. Long Coding Bytes missing
    By phil_w in forum VCDS (formerly VAG-COM) forum
    Last Post: 28th February 2009, 07:57
  4. CAN gateway long coding 9 byte help
    By GeoffT in forum VCDS (formerly VAG-COM) forum
    Last Post: 27th December 2007, 06:18
  5. VCDS Fault codes . . .
    By Olly_K in forum VCDS (formerly VAG-COM) forum
    Last Post: 1st September 2006, 15:29
