Chris NottJMB Retrofits
Results 1 to 9 of 9
Thread: Notchy steering
    Jun 2007
    69
    Notchy steering
    I'd like to get some experience from other owners before I go and moan at Audi.
    I've noticed, particularly on motorway runs that the electric steering on my A3 is very notchy, and by that I mean if the wheel is dead centre and I need to make a small correction it's not a smooth action when I turn the wheel, but there's a lot of force trying to pull it back to centre.
    Travelling up the M1 the other day at a normal speed (in efficiency mode) I was struggling to get the car to follow the bend of the road, as a small correction seemed to make the car lurch in that direction, whereas you'd expect small corrections to be smooth.
    Coming from a Scirocco which presumably had the same set up and never had this issue, I can only assume something isn't right?!
    Has anyone else experienced this?
    Jan 2013
    Cheshire
    96
    Is you car fitted with the lane assist feature, as I believe that tries to keep you in the lane by using the sterring to pull you back in ?
    Sep 2012
    15
    I have the same problem. But we are not alone, mate.
    It's a problem for the hole range of models with elektro mechanical steering. I've spoken with the dealer but they don't know what to do about it. On some german A3 8v forums they also talk about it. Some have gotten new steering system fitted, and it help. But for some it returns in a couple of days.
    I'm in for a checkup next week. It's the first reportet A3 8v with this problem i denmark, so the HQ wants to se if it's just like the other models.
    Jun 2007
    69
    Notchy steering
    No lane assist that I'm aware of.
    At least I know I'm not going crazy. On the whole, the steering works well (though a slight lack of feel) but the dodgy motorway steering is unacceptable
    number3's Avatar
    Nov 2012
    East Sussex
    335
    Have you tried different settings on the "drive select" button ?
    Audi A3 8v 2.0TDi S-Line, glacier white.
    Sep 2012
    15
    Quote Originally Posted by number3 View Post
    I can't feel any differens.
    Jun 2007
    69
    I have, happens across the board. It isn't noticeable all the time, mainly on motorways or also when the car is cold.
    number3's Avatar
    Nov 2012
    East Sussex
    335
    Worth a shot! Touch wood I don't get this problem which is why I though it might be down to settings! but I did on a courtesy i had last month from the dealer, which was an A5 so do know the issue your talking about !
    Mark.
    Jan 2013
    42
    Think mine may well be developing this little issue. Noticed it for the first time yesterday whilst on the motorway. Its very subtle but you can feel it, as if your steering past a notch for a fraction of a second. Tried it in two different drive select settings and its seems to make no difference. Only noticeable when sat on the motorway. Whether its coincidence too after about 20min of driving the "rest recommendation" warning is being triggered. Not sure what this warning takes its inputs from but i'm assuming steering patterns are monitored.
  1. pc steering wheels
    By badbaz in forum Video Gaming
    Last Post: 10th August 2003, 14:33
  2. Do you suffer from Notchiness???? Then you need...
    By s8n in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2003, 11:11
  3. Steering Wheel Remtoe for stereo?
    By AutoMatt in forum In-Car Entertainment
    Last Post: 8th August 2003, 08:07
  4. S3 Gearbox Oil for ridding Notchiness
    Last Post: 28th February 2003, 22:24
  5. Steering Judder
    By Drystone in forum Other Brands & Models
    Last Post: 6th January 2003, 17:28
