Chris NottSky Insurance
Results 1 to 10 of 10
    Feb 2013
    Derby
    353
    Running in the Engine
    Hi Guys,
    just wondering what your thoughts are on how you should run in a new engine? I've always had VAG diesels and on both occasions the salesman has told me to drive normally and the engine will be fine. In fact they said that the harder I drove it in the first few thousand miles it would actually improve performance! Not sure how true this is but I've put 106k miles on my 2004 A3 and 147k on my current Golf and I've never had any mechanical issues (touch wood!!)
    A3 Sportback 2.0TDI S-Line 150ps, Daytona Grey, Comfort Pack, Privacy Glass, SD Sat Nav, Through Load, Aluminium Pedals.
    Vertigo1's Avatar
    Jul 2006
    2,624
    The generally accepted advice these days is not to rev it too high for the first thousand miles or so. That said, you shouldn't take it too easy either. The first few hundred miles are critical in allowing the piston rings to bed in properly with the cylinders and, to do this, the engine needs a bit of loading.
    So, don't rev it too much and don't load it when cold. Once the engine is fully up to temperature though, do subject it to some decent loadings now and then as you drive, to help it bed in. Providing you don't do this when it's cold you'll be fine and it should help economy and performance in the long term. That's the theory at least
    Feb 2013
    Derby
    353
    Thanks Vertigo, looks like I'll be able to have a bit of fun with it when it arrives!
    27,096
    500-1000 miles take it very easy, then do as you see fit, was what I've always been advised/done, but letting oil get upto temps always helps & the dis can advise you of the temps anyway.
    dieseldoug's Avatar
    Oct 2012
    Aberdeenshire
    240
    Nail it when it gets hot and let it idle before switching off. These engines are all tested at full power before being installed in your car so don't worry. The days of running in ate finished unless you have very close fitting parts like F1 cars.
    A3, 2.0 TDI, S-Line, 6 speed manual, Scuba Blue, S-Line suspension, heated/folding mirrors, privacy glass, fine nappa leather, heated seats, light/rain sensor pack, flat tyre indicator, Purchased and supplied by Aberdeen Audi
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    Re: Running in the Engine
    My first advice, is spend an hour reading up, and making your own decision.
    There are 2 main camps of bedding in.
    Break them in gently. Not being too high revving, dont labour engine etc.
    Break them hard. Will be hitting full throttle runs almost straight away.
    I'm in the hard camp. I've rebuilt countless engines for my job. As well as replacing blocks etc.
    Also rebuilt my own engines, and ran them in hard. Never had issues, always had good power. My last personal engine, after initial start up and leak check, I hit full throttle with in 20-30 mins, and took it to 7k rpm.
    Rings do not take hundreds of miles to bed in. The honing on the bores is what your being in with the rings. That initial honing soon wears to a point it no longer 'beds'. After that, there will be no more bedding in of the rings.
    Rings need pressure to expand them against the bore. This comes from high rpm runs, and letting off.
    Conversely, cams need bedding in completely differently. They generally need to be held at 2-3k (manufactures have their own specs) for quite a while, last set I did was around 20mins.
    Engines are generally bench tested before installed. Thought I can't be sure every manufacturer does that. Plus it's already been driven around by factory staff, dock workers, transport drivers, valeters, salesmen, techs.
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
    May 2008
    557
    I've tried both approaches on various VAG engines over the years. Never had any reliability issues with either approach. However, breaking in gently seemed to improve oil consumption - I barely used 1ltr between services. Breaking in hard seemed to produce better power but had a tendency to drink oil more.
    2013 A3 Sportback 2.0TDi 150 S-Line - Daytona Grey, B&O, Comfort Pack, Interior Light Pack, SD Nav, Hill Hold Assist.
    2010 A4 2.0TDi 170 S Line | 2008 Golf GT Sport 140 | 2008 S3 | 2005 A3 2.0TDi 140 S Line | 2003 TT 225 | 1998 A4 2.8 Quattro
    Feb 2011
    187
    In my experience bedding in on new cars is ********. Had three new cars now and I've treat them no different to how i do when they have ten thousand miles and no issues whatsoever. Modern engines are designed to require as little as bedding in as possible
    1.4 TFSI 122ps A3 SportBack. Comfort pack, Audi sound system, Daytona grey, SD Sat Nav, S line trim. Love it!
    Feb 2013
    Derby
    353
    Thanks for the replies, can't bear the thought of driving around like an 80yr old!!
    Ben (T25) Ruz's Avatar
    Audi Virgin
    Jan 2013
    Chelmsford
    16
    I think it depends on the car/manufacturer. I have not bedded in my previous diesels (Honda/BMW) and will not be with the new A3. On the opposite end of the scale, with my Lotus they void the warranty if you red line in the first 600 miles!
