Monster MotorsportBadger5
Results 1 to 11 of 11
Like Tree3Likes
  • 1 Post By fishyfish
  • 1 Post By t8ups
Thread: Plug-and-play solution for DRLs (382/P21W) on A6 4F?
    Apr 2012
    Oxford
    126
    Hi Trups,
    I have bugged you before via PM about this, but I can't seem to get rid of a slight flicker with the LED day running lights I currently have on my 2007 A6 Avant (xenons with P21W DRLs).
    I get no errors, but I get a "pulsing" flicker every few seconds, and its just noticeable enough to drive me insane (and I fret about it come MOT time).
    I did grab a "canbus error canceller" from ebay, but couldn't get the barsteward to fit (not helped by the ridiculously tight access to the headlights), and I'd really like to avoid chopping into the wiring. Have you found or fabricated anything in terms of a plug-and-play bulb and/or loom that will cooperate with our cars?
    Cheers,
    Adam
    Jun 2011
    Wellingborough
    1,169
    Adam,
    Please send me a link of the cancellers you have and il tell you what to do to get them fitted in there.
    I want you to try them to see if that gets rid of the flicker.
    Trups
    SLOW REPLIES BETWEEN 22nd - 30th June due to been out the office, please bare with me. Thanks
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
    Apr 2012
    Oxford
    126
    These are the ones I got: 2 x LED WARNING CANCELLER P21W BA15s 1156 LOAD RESISTOR NO CANBUS OBC ERROR | eBay
    There just didn't seem to be a way to make that socket/holder match up to where the existing bulb holder goes.
    What I did notice is that the wires can be unplugged from the stock bulb holder via a two pin molex-ish plug arrangement, so I could conceivably insert something in the circuit if I could find the male and female bits to replace the bulb base and socket on the canceller...
    Cheers very much for any help you can offer
    t8ups likes this.
    Jun 2011
    Wellingborough
    1,169
    These will fit, 2 lugs need to be shaved off, i have these in stock, what i will do is take pictures later of the lugs you need to shave and they will fit in nice and tight.
    Trups
    EM Tuning Lighting.
    Jun 2011
    Wellingborough
    1,169
    Shave these 2 lugs off -
    That will then secure 2 in place and this will fit in solid.
    trups
    fishyfish likes this.
    EM Tuning Lighting.
    Apr 2012
    Oxford
    126
    Thanks a million for this, man... you are a life-saver!
    I have just managed to fit these thanks to your tip, and the flicker has been cured. Halle-bloody-lujah!
    PS: I presume, because the DRLs are not being run at full power, that the resistor box will not get hot enough to worry about, so it should be fine just stuffed inside the headlight with the rest of the wiring, right?
    t8ups likes this.
    Jun 2011
    Wellingborough
    1,169
    Ahhhh Great
    No they will be fine, i have sold to 2 members on here for their B7 and they have been going 3 months with no issues of them resting inside.
    Glad they all work.
    if anyone wants these ready to fit them let me know and i can supply with a Cree bulb
    Trups
    EM Tuning Lighting.
    May 2013
    10
    Hi Trups I am after changing my DRL to led on an S3 2007 can you supply the bulbs and resistors I would need.Many Thanks JakeS3
    Jun 2011
    Wellingborough
    1,169
    hi Jake.
    I can supply the bulb but this resistor will not work on the 8p S3.
    if you have access to VCDS then you can re code the Car to accept the LEd so it works error free.
    Trups
    EM Tuning Lighting.
    May 2013
    Hello, i have the same resistors as in the photo, also purchased from ebay. I have 25w cree led p21 bulbs but was getting bulb error warnings. Plugged the resistors in today to see if they worked and it stopped the bulb warning on my Audi a3 2006 with bi xenons. Was trying to figure out how to fit them as the socket was different but I see from your photo to shave off the 2 lugs and they will fit. Thank you for posting that, very helpful. I see u said to use vcds to recode to save using resistors. How do I re code. My friend has a garage and has a new snap on car computer is this able to recode or do I need some special vcds?
    Jun 2011
    Wellingborough
    1,169
    Hi.
    you do need VCDS to re code the car, other tools wont work im afraid. when I have tried these on the A3 in the past they have bought up the error still so only coding on the A3 as the BCM modules are completely different to that of a b7 or c6.
    EM Tuning Lighting.
  1. Plug and Play Tuning for the new 3.0 TDi 204 and 245ps
    By ABYSS in forum Diesel Tuning UK
    Last Post: 7th May 2012, 15:54
  2. Plug and Play Tuning option for the new 2.0tdi 177ps
    Last Post: 7th May 2012, 15:52
  3. Replies: 0
    Last Post: 11th November 2011, 09:07
  4. Replies: 4
    Last Post: 17th November 2008, 13:40
  5. Xenons are plug and play!
    By AkoyaMike in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th October 2006, 11:01
