Results 1 to 7 of 7
    Mar 2012
    Cumbernauld
    628
    Looking for advice
    Got the big 4.0 coming up in a few weeks,and hopefully if folks give me cash I'm looking to invest in a D.A. polisher(prob the dodo if in stock)and some goodies to clean up my brilliant red A3 V6,and remove some swirls and stuff-what goodies can you recommend along with other bits and pieces for the polisher,pads and stuff?
    Juicy Jen's Avatar
    Jen – Juicy Detailing
    Jun 2011
    County Durham
    835
    If your looking to concentrate on the polishing side then firstly you would need to fully decontaminate the paint work by using both an iron fall out remover such as Car Pro Iron X or Car Pro Trix (this combines tar removal as well) and then clay the vehicle. We offer various clay kits all of which are suitable and can meet a varying budget.
    Once the car has been washed and dried after decontamination you need to tape up the panels using blue Scotch tape (found in the accessories section). The reason for this is that you find the paint thickness is much lower in these areas therefore you are protecting yourself from any potential burn through.
    So your going to get yourself a Dual Action machine (we have quite a few dodo ones in stock at present) which will mean it will take slightly longer to correct hard Audi paint but it is achievable with patience. The biggest misconception about machine polishing is that is speeds up the process, whereas in actual truth is probably takes longer but the results are so much better and more permanent if you use the right maintenance techniques afterwards.
    Either the Chemical Guys V range of polishes (V34; V36; and V38) or the 3M samples pots are suitable in combination with the orange, green and black hex logic 5.5" pads.
    I would also get some Carpro Eraser which is used after polishing each section to remove oils and fillers which can mask correction. This enable you to see if any additional work is required.
    Once the correction has taken place you may need to wash the vehicle if the polishes have splattered everywhere or simply full wipe down with Eraser. I would then apply a coat of Chemical Guys EZ Creme and a coat of Dodo Juice Orange Crush wax to give you a nice wet look....
    If you need any more help just let me know
    Authorised Sponsor of Audi-Sport.net with exclusive offers for members
    2012 8P3 AKA The Green Goblin in Exclusive Java Green, Stage 1 Shark bite
    Mar 2012
    Cumbernauld
    628
    Cheers Jen,have used clay kits before so am ok there,as for the other info much appreciated.Will look into my upcoming budget .
    Have ordered a couple things from you guys before,and been looking at the dodo polisher too.Just need to talk to she who must be obeyed now
    Juicy Jen's Avatar
    Jun 2011
    County Durham
    835
    Treat her shopping and then its only fair if you have have something you want too
    Mar 2012
    Cumbernauld
    628
    Lol,my bank card has already taken a pounding lately...hope the pregnancy is going well.
    Mar 2012
    Cumbernauld
    628
    Any guides for using a DA polisher would be much appreciated,if you have any.
    Juicy Jen's Avatar
    Jun 2011
    County Durham
    835
    Drop me an email and I can get one over to you....juicyjen@ juicydetailing.co.uk (remove the space)
  1. Hello and Looking for advice on leather interior A4 avant
    By Block 405 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st August 2006, 16:34
  2. New Buyer looking for advice
    By andyhud in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th July 2006, 11:10
  3. newbie looking for advice on which audi
    By Siy in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th January 2006, 11:50
  4. New guy looking for advice
    By phaytan in forum The Welcome Section
    Last Post: 14th May 2004, 19:45
  5. New member, looking for advice on tuning
    By brookescourt in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th November 2003, 04:45
