Yet another group buy to add to the list!!!!
Sachs Performance Clutch and Flywheel Kits!
The clutch systems from ZF Sachs Race Engineering (ZF SRE) have brought motor sports teams worldwide to the forefront, from mass sports to Formula 1.
Successful technology, which has been developed built and manufactured by ZF Sachs SRE. Technology, which even in the Performance range means perfect tuning to the respective performance class of the vehicle, all to ensure optimal and safe transmission.
The fundamental advantage of performance clutches compared with OE clutches results in a higher life span and in a superior thermal resistance.
Discs with organic friction material have a superior burst limit because of pasting and riveting the clutch plates.
The friction coefficient of the sintered metal plates is very high which leads to a higher convertible torque.
Due to the reinforced clutch components, the pedal force can increase and the modulation range can be reduced. Additional clutch and gear noises can appear.
The below price listing is RETAIL including VAT for the organic kits.
Mk1 Audi A3 - 1.9TDI 6 Speed Gearbox FWD & 4WD
Sachs Performance Clutch Kit & Single Mass Flywheel - £1,214.69
Sachs Performance Clutch Kit for use with OEM flywheel - £616.69
Mk1 Audi A3 - 1.8T 5 Speed Gearbox - G60 Flywheel/Clutch Conversion FWD & 4WD
Sachs Performance Clutch Kit for use with G60 flywheel - £557.76
Genuine VW G60 Flywheel and Bolts - £149.50
Mk1 Audi A3 / Mk1 Audi S3 - 1.8T 6 Speed Gearbox FWD & 4WD
Sachs Performance Clutch Kit for use with OEM flywheel - £556.31
Mk2 Audi A3 / Mk2 Audi S3 - 2.0TFSI 6 Speed Gearbox FWD & 4WD
Mk2 Audi A3 - 2.0TDI 6 Speed Gearbox FWD & 4WD
Release Bearing for 6 Speed Gearboxes £40.75
Release Bearing for 5 Speed Gearboxes £31.07
FWD cars labour is charged at £207.00 which includes a 10% discount
FWD cars labour is charged at £258.75 which includes a 10% discount
Delivery is charged at £15.00 to UK Mainland
PLEASE NOTE: On new 2.0TFSI and 2.0TDI engines - When only clutch kit is ordered we will need to know if it is for use with the SACHS or LUK flywheel.
Now for the better part, discount levels!
up to 15 kits 10% Discount on Sachs parts
15 and above kits 15% Discount on Sachs parts
THE LIST:
1.
2.
All prices include VAT - If you have any questions please feel free to contact us on 01246 455005
Kind Regards
JBS Auto Designs Team
