JBSVAG Check
    Mr.G's Avatar
    Nov 2008
    In a Tardis!!
    1,303
    Post Thanks / Like
    1.8T Engine types & results from a Re-map!?
    Hi!
    I'm looking into a Re-map. You seem to be very competatively priced and have good feedback.
    My question is though, looking at various data i've trawled through via the internet etc the AMK engine and BAM engine are identical. Is the only difference the boost pressure upped a little to produce the 225Hp over the 210Hp for the AMK.?
    Why then is it not possible to see better results from a mapped AMK as the horsepower gains are more taking into consideration the 15Hp extra that the BAM has ontop of the AMK. Are both engines capable of the 270 "ish" Hp remap??
    So hypothetically in total the 225 would be capable of say 270Hp an increase of 45Hp.
    The AMK hypothetically capable of the same 270Hp giving an increase of 60Hp.
    Am i on the right lines here or am i totally off the mark???
    G
    JBS Sales's Avatar
    Feb 2007
    Chesterfield, Derbyshire
    336
    Post Thanks / Like
    Hi G
    Between the 210 and 225 engine the K04 turbos are ever so slightly different.
    The 210 engine will only see between 260-265bhp and the 225 will see between 270-275bhp.
    At the moment we are offering the Custom-Code Phase 1 remap, Forge 007P diverter valve and Green Cotton air filter for only £350.00 inc VAT fitted!!!
    Please call on 01246455005 to book in
    Mike
    Tel/Fax 01246 455 005
