JBS K03 Cast Manifold
Over the last couple of months the JBS development team has been busy working on a new cast K03 manifold.
Choosing to cast the new design over tubular was made easier by the design process. Casting the new manifold gives better quality mass production and gives fewer constraints on the pipe bend radiuses, allowing the runner to flow freely. The most obvious improvement being the manipulation of the runner from cylinder 3 into the collector.
The manifold has been designed in CAD to optimise the design, flow capabilities and to enable easier fitment. The CAD process allows the designers at JBS to manipulate the part quickly and while allowing information and measurements to be taken easily, which would be physically impossible to do by hand.
The design initially takes a similar shape to the successful JBS K03 manifold with the runners from cylinders 1, 2 and 4 all being tweaked for the casting process.
The main work has taken place in runner 3 and the box collector to achieve maximum material around the bolt holes to prevent cracking, found on the OEM and competitors manifolds. The collectors design also separates the runners to reduce port sharing of combusted gasses and aiming them towards the turbine in the turbo.
The box collector features cooling fins to minimise the effects of EGT’s on the manifold, preventing the manifold from warping and thermal fatigue.
JBS K03 SPEC
Fitment of the manifold was also a large consideration, the area around the head studs and nuts was maximised especially around the box collector to enable fitment via a double cranked spanner.
The cylinder head flange has been redesigned to allow greater thermal expansion and movement between the runners. The designers found that a too restrictive flange forced stresses back through the runners of the manifold which lead to crack propagation.
Once we were happy with our design it was sent off for rapid prototyping to give us a physical model to evaluate before any design finalisation can take place. The rapid prototype is a highly accurate model taken straight from the CAD data.
The RP (Rapid Prototyping) gives a huge advantage in being able to fit the part to an engine and turbo, to test and ensure that the product achieves its specification. We are also able to physically flow test our design and compare it to our CFD (computational fluid dynamics) data before being sent for casting. The data found from the flow testing has been very interesting. After placing the JBS K03 manifold against current products on market we found the JBS manifold not only flows a considerable amount more as a manifold but also due to the complex design and hours spent in CFD individual runner , balance, and flow were significantly increased.
JBS has chosen to cast its manifolds in a very high quality UK based foundry which is used by the likes of Borg Warner and many other OEM turbo suppliers to ensure the castings are of the highest quality. To reflect the high quality casting, we have chosen the same material as the hot side of the turbochargers D5S ni-Resist is a cast irons with high nickel content has the following properties: resistance to corrosion, resistance to oxidisation and high temperatures, resistance to wear and erosion. This is to ensure a minimal amount of thermal expansion and an equal rate of thermal expansion to the turbo housing, this again minimises the potential for thermal fatigue. The bolts for the fitment of the turbo to the manifold shall be supplied as they are a specific size and material to prevent stretching which leads to blowing gaskets.
Once the first batch of manifolds are produced, they shall be thoroughly tested and dyno’d. At which time all power and flow figures will be released. Once all testing is completed and we are happy with the results we aim to release the manifolds at £380 including bolts and VAT.
We also have an IHI stage one/ Garrett GT28 cast manifold going into production with the new ko3 manifold. As well as having K04 and Twin Scroll manifolds going through our design process and rigorous testing and hope to be able to bring them to you as soon as possible.
JBS Team
LinkBack URL
About LinkBacks
AUDI A4 TQS
My Build thread
