Works 60% the time, Everytime.
Originally Posted by
Just hunting registry for a setting to swap this over to my NAS mapped drive, found something under a SID that I thinks my username, has some homefile & default location settings in there, will play around more & change some to see if this affects my docs default location, also will check rest of registry for what I did in vista.
Obviously you have a different id on your machine than mine below, but shows the branches to look in as an example.
[HKEY_USERS\S-1-5-21-1509316327-2552989869-544126386-1001\Volatile Environment]
Edit. Ok go into windows explorer, right click on the My Documents folder directly under your username & go into properties & this will give you 6 tabs & one has the location you can set it for, sorted.
Yeh Im aware of that. Thinking about it, its probbaly only a problem if your running a domain and doing a redirect to your server.
Nevermind, Im being lazy and not going over 7 too much. I should really seeing as Im meant to support it.
2003 Audi S3 + Go faster bits
