GNJJBS
    indiemike's Avatar
    ZoomZoom
    May 2009
    North Wales
    381
    Post Thanks / Like
    PS3 surround sound help
    Ive got a sharp lcd tv which ive got set up with my panasonic surround sound system and running my ps3 through it to.
    The ps3 is connected via hdmi, and surround sound is scart connected, is there a way to achive full surround sound when using the ps3?
    The cinema system has no optical output
    Thanks mike
    My Much Missed :Imola Yellow S3 - Revo stage 2, SPS3, RS6 reps, Pirelli P Zero Rosso, Cupra R splitter, Brembo's, 323mm EBC Turbo Grooved Discs, Ferrodo DS2500 Pads, Forge DV, Forge FMIC, Fidanza Aluminium Flywheel, Sachs Clutch, Green Cotton Dynatwist induction kit, 3" Downpipe, sports cat, Milltek cat back, Bilstein B8's, KW rear adjustable tie bars Whiteline Adjustable ARB's, Eibach Springs, Powerflex Bushes, Bose Concert System
    My New Oil Burner : Seat Leon Cupra FR TDI
    Mar 2009
    38
    Post Thanks / Like
    if your surround sound has optical input, cant you use the opticals from the rear of the ps3 ?
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,058
    Post Thanks / Like
    second that, you need to run optical out the ps3 to and optical input on the panasonic surround system, if you havent got an optical in then you cant as scart wont do it.
    LOTS DONE, LOTS SPENT !!!!
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,811
    Post Thanks / Like
    the panasonic sound system, does it have hdmi input?
    if yes, you can send audio through hdmi to the panasonic system and then from the panasonic, output video signal via hdmi to the tv
    ^^ In my opinion
    Aug 2009
    169
    Post Thanks / Like
    I have a genius way of giving you the perfect sound from your PS3(I'm not being sarcastic either), have a look in the classified section cuz I'm selling a gamer chair. Once you plug in, all you can hear is the sound of the game. There is a sub in the back of the chair and speakers eitherside of your head.
    http://audi-sport.net/classifieds/sh...uct/3826/cat/8
    amimmortal's Avatar
    Jul 2004
    Edinburgh
    162
    Post Thanks / Like
    I have my PS3 hooked up to a Samsung LCD TV via HDMI only (the HDMI carries the sound to the TV too). I then have my TV Phono L-R analogue audio out plugged into my Phillips 5.1 system phono input and I get perfect analogue surround sound.
    I also bought an optical cable only to realise that the Philips system had a digital coaxial input, so I'd need an adapter. Haven't gotten around to it yet, but to be honest the sound quality through the analogue input is more than sufficient...
    My PS3, Sky HD box and Wii are all connected via HDMI/ Component respectively, with audio channelled to the surround sound via the TV Audio Out. Works very nicely and no need to muck about with the surround sound unit, just the TV source.
    A.
