DNA TuningSky Insurance
Results 1 to 9 of 9
    MikeSel^'s Avatar
    Systems Support Specialist
    Oct 2008
    Selby, Uk
    521
    Post Thanks / Like
    Talking How to speed up your PC
    A few of the basics to keep your PC in tip top condition
    By following a few simple guidelines, you can maintain your computer and keep it running smoothly. This article discusses how to use the tools available in Windows XP Service Pack 2 (SP2) and Windows Vista to more efficiently maintain your computer and safeguard your privacy when you're online.
    Free up disk space
    By freeing disk space, you can improve the performance of your computer. The Disk Cleanup tool helps you free up space on your hard disk. The utility identifies files that you can safely delete, and then enables you to choose whether you want to delete some or all of the identified files.
    Use Disk Cleanup to:
    • • Remove temporary Internet files.
      • Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).
      • Empty the Recycle Bin.
      • Remove Windows temporary files.
      • Remove optional Windows components that you don't use.
      • Remove installed programs that you no longer use.
    Tip: Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.
    To use Disk Cleanup
    1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Cleanup. If several drives are available, you might be prompted to specify which drive you want to clean.
    2. In the Disk Cleanup for dialog box, scroll through the content of the Files to delete list.
    3. Clear the check boxes for files that you don't want to delete, and then click OK.
    4. When prompted to confirm that you want to delete the specified files, click Yes.
    After a few minutes, the process completes and the Disk Cleanup dialog box closes, leaving your computer cleaner and performing better.
    Speed up access to data
    Disk fragmentation slows the overall performance of your system. When files are fragmented, the computer must search the hard disk when the file is opened to piece it back together. The response time can be significantly longer.
    Disk Defragmenter is a Windows utility that consolidates fragmented files and folders on your computer's hard disk so that each occupies a single space on the disk. With your files stored neatly end-to-end, without fragmentation, reading and writing to the disk speeds up.
    When to run Disk Defragmenter
    In addition to running Disk Defragmenter at regular intervals—monthly is optimal—there are other times you should run it too, such as when:
    • • You add a large number of files.
      • Your free disk space totals 15 percent or less.
      • You install new programs or a new version of Windows.
    To use Disk Defragmenter:
    1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Defragmenter.
    Click Analyze to start the Disk Defragmenter.
    2. In the Disk Defragmenter dialog box, click the drives that you want to defragment, and then click the Analyze button. After the disk is analyzed, a dialog box appears, letting you know whether you should defragment the analyzed drives.
    Tip: You should analyze a volume before defragmenting it to get an estimate of how long the defragmentation process will take.
    3. To defragment the selected drive or drives, click the Defragment button. Note: In Windows Vista, there is no graphical user interface to demonstrate the progress—but your hard drive is still being defragmented.
    After the defragmentation is complete, Disk Defragmenter displays the results.
    4. To display detailed information about the defragmented disk or partition, click View Report.
    5. To close the View Report dialog box, click Close.
    6. To close the Disk Defragmenter utility, click the Close button on the title bar of the window.
    Detect and repair disk errors
    In addition to running Disk Cleanup and Disk Defragmenter to optimize the performance of your computer, you can check the integrity of the files stored on your hard disk by running the Error Checking utility.
    As you use your hard drive, it can develop bad sectors. Bad sectors slow down hard disk performance and sometimes make data writing (such as file saving) difficult, or even impossible. The Error Checking utility scans the hard drive for bad sectors, and scans for file system errors to see whether certain files or folders are misplaced.
    If you use your computer daily, you should run this utility once a week to help prevent data loss.
    To run the Error Checking utility:
    1. Close all open files.
    2. Click Start, and then click My Computer.
    3. In the My Computer window, right-click the hard disk you want to search for bad sectors, and then click Properties.
    4. In the Properties dialog box, click the Tools tab.
    5. Click the Check Now button.
    6. In the Check Disk dialog box, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
    7. If bad sectors are found, choose to fix them.
    Tip: Only select the "Automatically fix file system errors" check box if you think that your disk contains bad sectors.
    Protect your computer against spyware
    Spyware collects personal information without letting you know and without asking for permission. From the Web sites you visit to usernames and passwords, spyware can put you and your confidential information at risk. In addition to privacy concerns, spyware can hamper your computer's performance. To combat spyware, you might want to consider using Microsoft Windows Defender, which is included in Windows Vista, and is available as a free download for Microsoft XP SP2. Alternatively, there are other free anti-spyware software programs available.
    Learn all about ReadyBoost
    If you're using Windows Vista, you can use ReadyBoost to speed up your system. A new concept in adding memory to a system, it allows you to use non-volatile flash memory—like a USB flash drive or a memory card—to improve performance without having to add additional memory. Learn more.
    Interweb Speeds
    Just about everyone suffers with the speed of their internet connection at one time or another.
    There are several things you can do to increase your internet speed, if you are fed up with banging you head against a wall whilst talking to your ISP, you could try 'tweaking' your PC's settings to get the most from your network connections.
    Many people over at Testmy.net have had success with VanBuren's cablenut, you can find out more about it here
    Be sure to backup any configuration files you may change before changing them just in case!
    It's may also be worth replacing your internet modem\router.. If you are using a USB Modem to connect to the internet, you may be surprised to know network ADSL firewall routers can provide a quicker internet connection then USB modem's.
    Happy Posting
    The opinions expressed here represent my own and not those of my employer.
    biggiep's Avatar
    Jul 2008
    155
    Post Thanks / Like
    Just for the sheer user freindlyness I think some people might like leaving the first section to a program like CCleaner, its free and very highly thought of. Just a little added tip because I know how daunting seeing lists of what to cleanup is rather than having them pre-set for you by a program.
    Biggie Biggie Biggie can't you see!
    2008 a5 3.0TDi Quattro. And for when I wanna go fast.... Suzuki B-King (Hayabusa with no fairing, think 0-100 in 5.1 seconds!)
    Olly P's Avatar
    My other cars a mk2 Golf GTi
    Dec 2008
    Oxford
    575
    Post Thanks / Like
    Or just buy a mac
    "If somethings not broken, keep fixing it until it is"
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,811
    Post Thanks / Like
    Quote Originally Posted by Olly P View Post
    Or just buy a mac
    Linux tbh....linux
    ^^ In my opinion
    Oct 2008
    880
    Post Thanks / Like
    Tuneup utilities 2008, or 2009, is a good application
    MikeSel^'s Avatar
    Oct 2008
    Selby, Uk
    521
    Post Thanks / Like
    I have been using SuSe from a long time now, but this is something I always get asked. I am not a huge fan of 3rd party utils for doing basic tasks, and I certainly wouldn't pay for them!
    Each to their own
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    Post Thanks / Like
    Quote Originally Posted by abdus View Post
    Linux tbh....linux
    For sheer user friendliness i'd vote for the Mac
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    Post Thanks / Like
    c cleaner.....defo
    Vehicle wrapping specialist
    NOW SOLD S6 Avant 4.2 V8....ooooo the noise hehe
    NOW SOLD '03 A3 TDi Quatty Sport Mods so far: Aerowipers front & Rear, Type R Sting ariel, 18" RS-TT Alloys, Superchips remap, Eibach Pro Springs -40mm, Bilstein B8 dampers, R32 ARB's Front & Rear, Pipercross panel filter
    MikeSel^'s Avatar
    Oct 2008
    Selby, Uk
    521
    Post Thanks / Like
    There's also - http://www.pcpitstop.com
    Which is an online scan.
