Badger5AH Fabrications
Results 1 to 11 of 11
Thread: PC sound?
    Jampublic's Avatar
    Taking it easy..
    Jul 2006
    Reading, SE
    972
    PC sound?
    My PC sound card sounds like its under water? I have checked and my PC or speakers are not full of water!
    Any idea what the reason for this is??
    J
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    Always update your drivers as the first port of call, after that
    Make sure on board sound (if you have it) is disabled in device manager or better still the BIOS
    Check sound card is seated properly
    Unplug and re-do all the cabling
    Skint because of my car, the forums made me do it
    Jampublic's Avatar
    Taking it easy..
    Jul 2006
    Reading, SE
    972
    Ok I will look in to that!!
    J
    Jampublic's Avatar
    Taking it easy..
    Jul 2006
    Reading, SE
    972
    Errr i may need some more help, drivers seem up todate! I will shut it down and check the internals! Fingers crossed!
    J
    Jampublic's Avatar
    Taking it easy..
    Jul 2006
    Reading, SE
    972
    Ok I have a DELL 3100 Dimension and it as some kind of built in sound card, not an actual sound card as per a normal PC!
    I did shut down and check the internal connections, everything seems fine! I disconnected the speakers and reconnected them, no change!
    Any thoughts
    J
    JJ
    4th gear
    Mar 2008
    Near Salisbury
    44
    Go into the mixer section on your audio card and see what your speakers confiig is-while your there check no FX are being added.
    In your situation i would remove the card from windows and install again,might be a quirky bug that vansihes if you install again
    hope you get it fixed,always a nightmare when something in the pc plays up and steals valuable time from you-also bloody frustrating!
    08 A3 Sportback SE TDI S Tronic 170 Ice Silver
    Front sports seats Alcantara/leather
    Jampublic's Avatar
    Taking it easy..
    Jul 2006
    Reading, SE
    972
    still no luck!
    Thanks for your sugestions, the problem pursits!
    J
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    have you tried another set of speakers?
    if you look in control panel do you have any sort of sound card config or maybe in the system tray? on mine its a blue square with a white triangle in it (soundmax audio) because as JJ says I can select an underwater sound effect, god knows why.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    You have got an onboard sound card called a Realtic Ac97. there not the best sound quality any way but it should not sound like that.
    check your card has not got 1 of the "virtual surround" settings on.
    Also if your using somthing like winamp to play your tunes, check the "DSP/effects" is not on.
    it sounds like its playing at very low bitRate so check sound settings on sound card is set up right.
    hope that helps mate
    Now to many mods to list! Lots of power, torque and Leather!
    Chepstow, South Wales
    620
    Have you got a pair of headphones you can stick in to see what the sound is like then? This will help you determine whether it's the speakers or the computer
    27,007
    Yeah I would try headphones see if has same sound, could even be the powered amp/woofer at fault, try moving speakers around as maybe one output to speakers, another speaker set, even if latest drivers could be corrupted so download them again from Dell with service tag & install again, restart see if has any effect, Realtek also has them on there site but you'd need to know your audio chipset so dont bother, the virtual room surround effect settings could create that effect like Hall, Stadium etc, so check the Realtek speakers settings as I'm leaning towards this, onboard audio doesnt go wrong very often TBH so I'm not convinced its hardware faulty but try all the above.
